1999+ F250/F350 Front Axle Specs - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-01-2008, 11:42 PM
nierace nierace is offline
nierace is starting off with a positive reputation.
I've searched for a while trying to find a site that has a bunch of specs on the front axle on the F250's & F350's but have been unsucessful. I would really appreciate a link to a site that has information on the front axles found in those years, ie if they're high pinion or low pinion, how wide they are (WMS) stuff like that.
Thanks for any input.
Old 03-02-2008, 11:04 AM
Bump for the Sunday crew...
Old 03-03-2008, 09:14 AM
Bump again :O
Old 03-08-2008, 12:02 PM
No body knows the specs of their axle sitting up front ?
Old 03-08-2008, 01:02 PM
anotherfordguy anotherfordguy is offline
anotherfordguy is starting off with a positive reputation.
Its either a D50 or D60 depending on the year and build. Outers are the same on both. inner axle shaft lengths are 15.39" and 37.69". Stub shafts are 9.39"
All ford front axles housings are high pinion reverse-cut gears. Dont know the wms length without measuring it. I have a F450 axle in mine now since I bent the D50 I had. F450-550 axle housings are about 2" wider.
Old 03-08-2008, 02:36 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
My 04' SD has a F250 Dana 60 up front and a Sterling 10.5 out back.
Earlier SDs had the Dana 50 up front but I'm unsure of what year they started putting the Dana 60 in the front of the 250 and 350 SDs.
Maybe you can get some specs from Dana.
Old 03-08-2008, 03:22 PM
So they're all HP, thats what I really wanted to know
Thank you guys !
Old 03-08-2008, 10:15 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Quote:
Thank you guys !
Should've asked! Your op said you were looking for a site with the information. Obviously no one had one or they would have spoken up. Glad we got your Q answered though!
Now I have one, showing you can always learn something new. What is wms? Wheel mounting surface? Just a guess.
Front axle swap 1jeffm 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-05-2015 12:00 PM
Axle/Axle swap questions. wils3825 1994.5 - 1997 7.3L Power Stroke Diesel 27 01-06-2015 10:34 PM
2004 F250 front axle question joe blow Clutch, Transmission, Differential, Axle & Transfer Case 0 07-25-2014 04:00 PM
1975 F250 highboy axle swap fordtruck76_390 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-19-2008 12:57 PM
2006 F350 FX4 specs? shipper 1999 to 2016 Super Duty 5 04-12-2008 12:26 PM
Tags
04, 105, 1999, 19992006, 2002, 99, axle, axles, f250, f350, front, specs, superduty, type, wms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
