Squeaky front end
Squeaky front end
I'm new to this forum, but have found TONS of useful info so far. I was hoping someone could help me out with troubleshooting the squeak I hear in the front driverside of my 97' Ford PSD. I saw my springs were shot, so I replaced them, and the shocks in the front. I then wasn't happy with the hieght I gained with the new leafs, so I put a add a leaf on it. I replace the Leaf mounting shackles, bushings etc... Still with I hit a pot hole it sqeaks. So I checked the cab mounts, and they look like new. I like to consider myself mechanically inclined...but I've exhausted any other ideas...everything looks straight. Any ideas. Thanks in advance for any input.
check the rivots on the spring mounts at the frame, but usually they clunk, not squeek.
when you say you replaced all the hangars and bushings did you also replace the bushings up front on the hangers by the bumper that mount inside the frame rail?
also is this a 250 or a 350? if its a 250 then you have axle pivot brackets that could be squeeking.
3rd, does it have sway bars? check the bushings on them as well
It's a 250, and I replaced the bushings on the front next to the bumper where it drops down to the actual hanger. I haven't really considered the rivets cause they looked solid. But I haven't checked out the pivot brackets. What a silly design by the way...those twin I beam front ends. Wish I had to cash to put a solid front end on. Thanks for the tip, I'll have to check it out tomarrow.
i am really happy with the independent front axles, they ride smoother in my opinion and when you go 4 wheeling they are more agile then the straight axles.
craw under and take a good look at the pivot bushings, you may find they look horribly displaced. mine where god awful, had to look twice because i couldnt beleive how bad they really were
