2003 Explorer-weird front end noise
03-01-2008, 04:45 PM
on
I have changed the hub and bearing assembly and still are experiencing a thumping and whining noise in the front end. Any suggestions?
03-01-2008, 07:01 PM
maybe drive shaft universal joint? i would jack front wheels up a few inches, rotate the drive shaft and wheels--- look around, look at axle pinion movement, etc.
03-03-2008, 02:21 PM
Thumping noise - might be the tire. Not sure about the whine.
03-04-2008, 01:35 AM
on
Changed both left and right hub & bearing assy.'s and check the u joint on the front drive shaft all are good.
nateairman
835
04-21-2020 08:43 AM
denny7170
07-03-2016 09:38 PM
kconrad
08-01-2015 11:35 AM
Tyleryac
05-31-2015 10:51 AM
dougcepress
1999 to 2016 Super Duty
12-07-2014 08:16 AM
