Engine compartment question.
Watch the ignition coils, too. They don't like water either. You could end up with a misfire or even worse a multiple misfire that can damage you catalytic converters if it was bad enough. I've seen lots of guys have to put out big dollars for repairs all because they washed their engine. I use as little water as possible and remove any excess with compressed air. If you are careful you shouldn't have any problems. The solenoid you are looking for is mounted to the firewall on the passenger side. (behind the battery)
