Multiple Displacement Engines ???? adapt your own
Old 06-05-2008, 10:41 PM
sixtyfive_ford's Avatar
sixtyfive_ford
sixtyfive_ford is offline
As you may well know about the gmc MDE or something like that, Multiple Displacement engines. As far as I understand they take a v8 and under regular driving conditions they "turn off" four of the cylinders to result in improved fuel milage. When you step on the gas it "turns on" these cylinders for the extra horse power.
My question is how are they "turning off and on" the cylinders? Is it just switching off the injectors to 4 cylinders? and if so could I do this to my vehicle (wifes Ford Escort) with a dash mounted switch to shut off 1 or 2 injectors of the 4. I could switch them on when I needed them and off when I'm cruising under no load. It may or may not throw codes but I don't care.
I drive 120 miles roundtrip a day to work and I have alote of time to think
any thoughts???
Old 06-06-2008, 05:03 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
They also deactivate the lifters for those cylinders to reduce pumping losses.
Old 06-06-2008, 07:24 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
GM and Chrysler both offer this on several engines.
GM calls it "Active Fuel Management", Chrysler calls it "Multi Displacement System".
If you Google those, you can see how those companies did theirs.
Ironically, Ford said back in 2001 that they would have engines doing this within 24 months. I think they're over-due.
Steve
john jamieson
1983 - 2012 Ranger & B-Series
11-26-2016 05:43 PM
swampdog55
1997 - 2003 F150
11-26-2015 04:25 PM
Driver Jim
General Diesel Discussion
07-23-2014 07:33 AM
nossliw
23
11-09-2012 06:50 AM
justing
1997-2006 Expedition & Navigator
09-13-2005 07:45 PM
Quick Reply: Multiple Displacement Engines ???? adapt your own
