Where to buy good PCM online or Memphis area
Old 02-29-2008, 05:48 PM
aocabrown's Avatar
aocabrown
aocabrown is offline
After a long string of troubleshooting, including an IDM replacement....shop says the codes are still indicating IDM. I can't remember the code...1494 comes to mind but that probably isn't right. The code happens somewhere during the KOER or KOEO tests.
Somewhere on here I read theFord diag for this code and it says replace IDM and re-test. Done that. Then I believe it says replace PCM and re-test.
I don't want to pay $900 to stealership to 'try' a PCM. Have considered getting one from Jody (with or without tune) or having Jody try to flash mine.
Anyway....does anyone know of a place to get a PCM or is anyone in the Memphis area willing to do a quick PCM swap so I can verify my problem?
THANKS!!!
Old 02-29-2008, 06:13 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
Jody would have one for a round 300 bucks...ebay has them cheap some times too
Old 02-29-2008, 08:17 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
THANKS!!!
I'll meet you somewhere and do it. Problem is I am working weekends for the next 3 weeks. It is a vicious cycle for me. As you also know, we are not exactly close either. The only good thing is the swap takes about 10 minutes max to do.
I cannot believe there is nobody in Memphis. Let me check something out.
Old 02-29-2008, 08:22 PM
justblowin'smoke's Avatar
justblowin'smoke
justblowin'smoke is offline
the dealer wants 900????? i paid 400 for mine from the local dealer and if i remember right they give u a hundred back when you turn urs in
Old 02-29-2008, 08:43 PM
Tenn01PSD350
Well, I guess I better get my believer meter fixed cause I cannot find any. Wonder if anyone is in Arkansas just across the river?
Old 02-29-2008, 08:52 PM
aocabrown's Avatar
aocabrown
Surely there is but haven't run across any on FTE. I have an email in to Jody and a bid on an Ebay unit. If the bid doesn't go to high and I get lucky I'll go that route.
Old 03-03-2008, 09:11 PM
aocabrown's Avatar
aocabrown
Hey guys...found several on the internet (one listed below). How can I verify which PCM(s) are ok with my 2001 truck? Anyone have a good site or resource?
2000 Ford F250/F350 7.3 Litre PowerStroke Diesel Truck Computer ** Automatic Transmission
NVK5
EEC-V
XC3F-12A650-BG
Computer came from a running vehicle, but there are at least a 100 different computers for the 7.3 litre Diesel Powerstroke ... please contact Ford to see if this will work with your truck.
Old 03-03-2008, 10:20 PM
Tenn01PSD350
I am pretty sure your truck will work with a NVK or PMT PCM. I know pretty sure does not cut it, but that is as far as I am willing to go on your dime.
Old 03-04-2008, 12:59 PM
aocabrown's Avatar
aocabrown
I wonder what would happen if you put in a slightly wrong one. I've read there can be 10-12 different ones for a 2000 or 2001 model truck. The one I'm about to receive is a Part Number: F81F-12A650-NE
Old 03-04-2008, 01:00 PM
aocabrown's Avatar
aocabrown
To be more exact...says FVT4 on it.
Old 03-04-2008, 03:18 PM
Action4478's Avatar
Action4478
Action4478 is offline
You can try ..car-part.com ,,& sort by distance ,,,I got one for 50.00 ....
OldWoodsDiesel
37
01-13-2020 11:53 PM
roostercrows
28
04-06-2017 03:12 AM
noober0x
1999 to 2016 Super Duty
09-13-2016 07:17 PM
vegtoph
24
12-06-2014 12:11 PM
danboy282
Bronco II
02-29-2012 06:35 PM
Quick Reply: Where to buy good PCM online or Memphis area
