Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-29-2008, 11:40 AM
jbolivar jbolivar is offline
jbolivar is starting off with a positive reputation.
Dana 60 reliability question
Anyone have experience with a 16 spline Dana 60 with power lok? I'm mainly interested in the reliability of the 16 spline axles. Thanks
  #2 (permalink)
Old 02-29-2008, 04:58 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE. RCrawler is gaining momentum as a positive member of FTE.
As compared to what? The coarse splined axles are notoriously weak for anything but a stock application. You can upgrade them to 30 spline axles, but you need to change the carrier.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 03-01-2008, 09:12 AM
redvalley's Avatar
redvalley redvalley is offline
redvalley is starting off with a positive reputation.
If you're not puting too much power to 'em the 16 spline axles should be ok under your small bronco. I would think it would last pretty well with the power-lok, then when you get tired of one wheel spinning when you get stuck off-road (the limited slip is pretty much good for traction on pavement or a good dirt/gravel road) and move to a locker (or spool) get one that replaces the carrier (ie detroit) and upgrade the axles too.
  #4 (permalink)
Old 03-01-2008, 01:11 PM
RCrawler's Avatar
If you are swapping a 16 spline Dana 60 into a Bronco, you are actually losing strength. The stock 28 spline 9" axles are stronger. If you are switching over to 8 lug, find a mid 70's up Ford Dana 60, a Sterling 10.25, or a GM 14 bolt. They are cheap and plentiful, and stronger than the early Dodge Dana 16 spline rearends.
Jason
__________________
  #5 (permalink)
Old 03-01-2008, 05:17 PM
play400 play400 is offline
play400 is new and has a neutral reputation at this point.
Be better off spending the $$ beefing up your 9" than putting that heavy unsprung load in your truck. I ran a nodular housing, large pinion support with 28 spline axles and never broke the back. Played real hard every weekend. Always wanted to try the 9" in the front as the 44's axles fit it but never bothered because the stock axles even with the big u-joints were always my downfall
  #6 (permalink)
Old 03-02-2008, 08:35 PM
redvalley's Avatar
If you're going to the eight lug and got the 16 spline axle already for free it's a good place to start. Then when you get money you can upgrade the axles and carrier. The extra unsprung weight does have a few benefits, and like I said if you're not pushing too much HP it should be ok.
  #7 (permalink)
Old 03-25-2008, 08:38 PM
Trevor1's Avatar
Trevor1 Trevor1 is offline
1979 Ford Bronco
Trevor1 is starting off with a positive reputation.
i have a 1978 f250 dana 60 (35 spline) rear end in my 79 big bronco and the big rear end is bulletproof and it eliminated wheelhop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
