More Fluids
There should be two plugs on the passenger side of the tranny (at least there is on the HD 3 spd). One on the bottom and one on the side. The fluid should be just up to the bottom of the side plug hole. That's also where you fill it - unless you pull the top shifter cover and fill it from there.
