this darn fuel leak!
Old 02-28-2008, 09:07 PM
2 stroke man's Avatar
2 stroke man
2 stroke man is offline
i tightened it up on the pump side, and it kept on, although the clamp was loose on that side.
Old 02-28-2008, 09:15 PM
Hussler's Avatar
Hussler
Hussler is offline
Well, there is also a clamp on the canister side that you just can't see without a mirror. The only way to tell for sure is to look. I too thought my final leak was at that location but found it was actually on one of the sensors that dripped down and just made it look like it was coming from that area, about 1 drop per second.
Old 02-28-2008, 09:17 PM
2 stroke man
if i park my truck for a bit there will be a lil puddle under her about the size of a saucer
Old 02-28-2008, 09:23 PM
Hussler's Avatar
Hussler
Hussler is offline
Get some paper towels and with a long screwdriver poke them down there and clean it up as good as you can. Will probably take .. maybe 10 minutes. Fire it up and watch for the leak.
Old 02-28-2008, 09:26 PM
2 stroke man
kewl. will do tomarry.
Old 02-28-2008, 09:33 PM
kawa's Avatar
kawa
kawa is offline
I had the water sensor crack on me once and it leaked a good amount and I thought it was coming from under the filter.
As everyone else has told you, ya just gotta mop it dry. The dryer the better. Ya really need some help on this, someone to start and stop the engine so you can have you mirror at the ready. Don't foreget to make sure that everything else is clean and dry like the filter bowl and all surrounding lines.
If you create a clean playpen you will find the leak.
Rog
Old 02-28-2008, 09:37 PM
2 stroke man
the water sensor is the black one on the side of the FPR right? i done replaced it before.
Old 02-28-2008, 09:49 PM
kawa's Avatar
kawa
kawa is offline
How long ago? and make sure that it and everything else on that filter is clean and dry before you have someone else fire it up.
Rog
Old 02-29-2008, 04:35 AM
MLCinNCTX's Avatar
MLCinNCTX
MLCinNCTX is offline
its comin out the back.
You might want to make sure the bottom of the canister has not "rotted through" and is seeping fuel. If you do have to pull the filter can, I would replace the hoses while the access was there.
Old 03-03-2008, 10:45 AM
Kentuckyrocks's Avatar
Kentuckyrocks
Kentuckyrocks is offline
I've got the same problem and it just takes persistance and patience with help from this site
deshet1980
07-13-2015 07:40 PM
Crazy2
01-16-2012 05:05 PM
97biostroke
01-06-2011 03:51 PM
1979FordF250
15
11-25-2007 07:56 AM
TakeEm
11-08-2005 08:53 PM
Quick Reply: this darn fuel leak!
