Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-27-2008, 07:42 PM
Strut61's Avatar
Strut61 Strut61 is offline
Strut61 is starting off with a positive reputation.
08 Break Down!
Ok OK , I know.....I too hate the he said, she said BS but. On this one I was actually speaking to the owner so, Here goes.
Tonight on my way home from work, about 5:45pm. Heading down Rt 11 toward Danville Pa I notice a big 5th wheel trailer, Truck and a Tow Truck!
On my way past this, I looked to see and sure enough it was an 08.....So, I spun around to be nosey and to see if I could help.
Well, the Gentleman was Hotshot hauler out of Vermont and was heading from Indiana to Conneticut with a Landmark 5th wheel approx 36' in lenght.
He told me the truck, an 08 F350 6.4, had 5,000 miles on it and this was the 2nd time the truck has let him set. The 1st being a frozen up air Filter due to sucking snow into the intake and clogging the available air form the motor. Now this, he stated.....I asked what was up and he told me that all of a sudden he lost steering and upon trying to slow to a stop, noticed he had no brakes? He had to use the emergency brake to stop the vehicle in a safe manner. He then called Ford Roadside and they called Enterprise and got a tow truck to take the truck to Jack Metzer Ford located in Danville, Pa. The 5th Wheel was un-hitched and left set with a pin lock applied.
Anyway, I hauled this fine gentleman to the Dealership as the Tow vehicle was lagging behind, and sat there with him (as it is freezing out) till the Rental Car showed up.
I doubt I'll ever hear what caused the issue...........It's wierd that two seperate systems failed at the same time.
Anyone else hear of such a thing.
__________________
2008 6.4L F450 Lariat, 4:88's , Line-X, Vent Visors
2006 Cedar Creek 362BTS and Lots of stuff!
  #2 (permalink)
Old 02-27-2008, 08:00 PM
1968gtcs 1968gtcs is offline
1968gtcs is starting off with a positive reputation.
Well after having to replace a power steering pump on my 02 Excursition, I found that the power steering pump is also used for the power brakes. They are on the same system. My guess is he blew one of the hoses (Intake or return line) which caused the loss of breaks and steering. If the Pump just went out he would have at least had the breaks, just not power assisted brakes. This would be my guess.
__________________
http://www.ford-trucks.com/user_gall...photoid=156450
2008 F450 6.4L, 5 Speed Auto, 4:30, 4x4 Lariat DRW LB Crew Cab, Dark Blue Pearl, SS J&J Running Boards,
  #3 (permalink)
Old 02-27-2008, 08:37 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE. Dustin1690 is gaining momentum as a positive member of FTE.
Whatever caused it all i know thats scary stuff especially pullling a 5er
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #4 (permalink)
Old 02-27-2008, 09:22 PM
Sayonara Sayonara is offline
Sayonara is starting off with a positive reputation.
Wow what a mess. never heard of that but good thing everyone was safe! Pretty scary stuff to think about as i use my SD for hauling our TT with the family.
__________________
DT
2008 F350 CREW CAB, LARIAT, 6.4L DIESEL, 20% TINT, SHORT BED, MOONROOF, 20's, RHINO LINER, BEDRUG, Leer 100XQ CAP
TT: 2008 OUTBACK SYDNEY 32BHDS
http://thomasfamily1998.smugmug.com/...53_aF7Ka-S.jpg
  #5 (permalink)
Old 02-28-2008, 09:36 AM
barry1me barry1me is offline
barry1me is starting off with a positive reputation.
The brakes...almost every diesel truck made is Hydroboost. most work in conjunction with your powersteering. Some diesels have a vacuum pump and then you can use a standard duplex like a gasser. (I was an intern at TRW when I was in college, so I have some brake knowledge) Since diesels do not make vaccum they can not use a typical booster like a gas engine to help with braking.
  #6 (permalink)
Old 02-28-2008, 10:37 AM
Bowie Bowie is offline
2003 Ford F-350
Bowie is starting off with a positive reputation.
JOb 3 trucks here are the brakes:
Power 4- wheel disc/4-wheel anti-lock brakes with vacuum
boost are now standard on SRW with all engines. Power 4-
wheel disc/4-wheel anti-lock brakes with hydro-boost are now
standard on DRW with all engines, included on SRW with the
Dual Alternators, and optional on SRW diesel for fleet only.
  #7 (permalink)
Old 02-28-2008, 01:50 PM
firehawk198's Avatar
firehawk198 firehawk198 is offline
firehawk198 is starting off with a positive reputation.
[quote=Strut61]Ok OK , I know.....I too hate the he said, she said BS but. On this one I was actually speaking to the owner so, Here goes.
Nice guy, hope if I ever breakdown it is near this fine gentleman home. Great post Strut, this will help us all to learn alot. Did not realize they were on the same system.
__________________
http://www.ford-trucks.com/user_gall...photoid=1645522008 F450 4x4 4.30's Dark Toreador red delivery 4-05-07 13.46 mpg mty 8.64mpg towing 16,950# over 4,800 miles
99 F350 V10 DRW 3.73's 5 speed stick traded 11.5mpg
1995 Firehawk 315hp 6 speed 06 Escape 22mpg
93 40th Anv. Vette, 2006 Armada, Kountry Star 5'th wheel 40'
  #8 (permalink)
Old 02-28-2008, 03:13 PM
Strut61's Avatar
Thanks, I did what any one of us would have done in the same instance. Thanks again!
I did not realize they were on the same system either, but as described earlier in the post I guess they are. Sort of disturbing, to think that if you loose steering you also loose your braking ability!
This fella told me he also had an F550 with a cummins and in excess of 1 million miles that he intended to get out of moth balls. He was really pleased with the truck as a whole but very disenfranchised by being left sit twice inside of 5,ooo miles.
I don't think this repair is a bank breaker, but, a retired fella, just making ends meet sure does not need this additional headache. None of us do.
Oh by the way, Fords answer to the frozen air filter was, buy a grill cover! Imagine the nerve, spend in excess of 50k on a truck and Ford won't spring for a $20 cover....Thanks Ford!
__________________
  #9 (permalink)
Old 02-28-2008, 04:16 PM
Oh man i hate to say it but thats bs alright you spend how much on a superduty and they tell you to get a grille cover for it
__________________
My Truck:
Dad's Truck:
  #10 (permalink)
Old 02-28-2008, 04:47 PM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
2004 Ford F-150
My Garage
fordtruckman has a good reputation on FTE. fordtruckman has a good reputation on FTE.
You would think that there would be a fail safe so that if something did brake with the system you wouldn't just be left out in the dark so to speak to save yourself. I mean what the heck would he do if he was in the mountains or something. Whoa I'd be freaked out by that.
__________________
Matthew | 2004 Ford F150 STX | 2007 Ford Fusion SEL | Michigan Chapter member | "Snow Plowers" member
  #11 (permalink)
Old 03-01-2008, 11:16 AM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
My friend got an 08 PSD for a company vehicle. He's a big shot at Syngenta, anyway he said he had to put the grill cover on to keep snow out of the air intake. Otherwise he said the truck had been trouble free.
  #12 (permalink)
Old 03-01-2008, 01:18 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
FTE Addict
diesel_dan is gaining momentum as a positive member of FTE.
That's interesting -- my friend just picked up their Job 3 build truck a week ago Friday and it is an F250 4x4 and it specifically states hydroboost on the sticker... Nothing they asked for and it's a Lariat, so not a fleet truck...
__________________
'07 F350 SRW SC/LB, 6.0 PSD/Auto, 4x4 -- SuperHitch w/ custom 16" SuperTruss, Tork Lift Camper Tie-Downs, Rancho RS 9000X Shocks, Air Lift Air Springs, BFG A/Ts 285/65/18E (replacing failed 305s), GO Industries Mud Flaps.
'00 Expedition 5.4 4x4 Eddie Bauer, 3.55 LSD, HD Tow Pkg & Air Suspension -- All Bone Stock
  #13 (permalink)
Old 03-01-2008, 10:51 PM
I mentioned this TSB to my deaker and they ordered the parts for me. no charge.
__________________
DT
  #14 (permalink)
Old 06-30-2009, 10:59 PM
fulmar fulmar is offline
fulmar is starting off with a positive reputation.
First time posting on the forum. Thanks for any help you can provide.
The same thing happened to me tonight...got in my truck to leave work, turned the steering wheel a small amount, heard a "pop" from under the hood, and then lost all power steering and 90% of brakes.
Truck is an '09 250 6.4 Lariat with under 2k miles. I looked in the owner's manual, couldn't find a fuse or relay which would control both the steering and brakes and then i searched this forum and found the exact same thing happened to another unlucky guy. Looks like it needs to be towed to the dealer. Good thing I wasn't on the highway or going down a hill.
  #15 (permalink)
Old 07-01-2009, 12:01 AM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
2008 Ford F-350
Brandon D is starting off with a positive reputation.
Thanks for the heads up, hope it never happens to me but nice to know what it is if it ever does happen. Just wanted to comment that they provide us all with factory grille covers up here in Canada. Or at least they did to me and a friend, I would think they should extend the courtesy to those down south that live in the snowy states. I have already had my air box plugged off once by snow but it never killed the motor, just told me to check the air box on the instrument panel. Lucky too cause it was brutally cold that day. The grille cover probably would have helped but I tore out my factory grille a month after I bought the truck so the cover doesn't fit anymore. Not real practical when it snows but MAN does it look good, haha.
__________________
2008 F350 CC FX4 6.4 PSD
3.73, 20" factory rubber
S&B CAI, Pro Flo Exhaust, 275 & 310hp Spartan Tunes, T-Rex Billet Grille, Billet Side Vent Inserts, 50 Gal Titan Tank, 100 Gal slip tank/tool box combo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
