I have a 1993 ford f-150 flareside with 351 windsor
I have a 1993 ford f-150 flareside with a 351 windsor. I was wondering what performance truck had a 351 windsor that i can get parts from for my motor. My truck is 4x4 and standard cab with auto transmission. also what visual upgrades as well? any and all help will be appreciated. thanks
Well, whatever engine differences there are between the normal production 351's and the 351's that came in the Gen 1 Lightnings would be a start.
Blurry would be able to point you in the right direction for mods that would work well for your engine too, as well as your appearance upgrades.
Stewart
Stewart
You won't be able to buy the Lightning stuff cheap so you might as well buy new aftermarket parts.Plus the lightning stuff will limit you depending on what your goals are.Spend the money on aluminum heads,intake and cam. Headers are easy to do plus the aftermarket has alot for exhaust systems.
The 351w engines are pretty much the same. After 1993 Ford used the roller blocks which were just blocks cast to allow roller cams.
best bet go to junk yard look for the exhaust manifolds and as well ask for other parts that match up to your model as i am not familiar with the lightning engine but i have a 351w to put in my truck later as i was going that same rout put just the exhaust as well as the heads if i can use my carb on there so good luck ..luv my ford truck
Ford4you
04-19-2016 07:58 AM
sengel1975
24
05-26-2015 08:34 PM
bigcountry1990
03-16-2015 07:47 PM
Benefiel
05-15-2014 08:52 AM
