Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 02-27-2008, 10:48 AM
93fordflareside351 93fordflareside351 is offline
Garage is empty, add now
93fordflareside351 is starting off with a positive reputation.
I have a 1993 ford f-150 flareside with 351 windsor
I have a 1993 ford f-150 flareside with a 351 windsor. I was wondering what performance truck had a 351 windsor that i can get parts from for my motor. My truck is 4x4 and standard cab with auto transmission. also what visual upgrades as well? any and all help will be appreciated. thanks
  #2 (permalink)
Old 02-27-2008, 11:58 AM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
I think you would be better off in the forum for your truck. Very little from the Lightning will work on your truck unless you put a L top end on it.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #3 (permalink)
Old 02-28-2008, 02:20 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Well, whatever engine differences there are between the normal production 351's and the 351's that came in the Gen 1 Lightnings would be a start.
Blurry would be able to point you in the right direction for mods that would work well for your engine too, as well as your appearance upgrades.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #4 (permalink)
Old 03-15-2008, 04:48 PM
86caprirs's Avatar
86caprirs 86caprirs is offline
86caprirs is starting off with a positive reputation.
You won't be able to buy the Lightning stuff cheap so you might as well buy new aftermarket parts.Plus the lightning stuff will limit you depending on what your goals are.Spend the money on aluminum heads,intake and cam. Headers are easy to do plus the aftermarket has alot for exhaust systems.
The 351w engines are pretty much the same. After 1993 Ford used the roller blocks which were just blocks cast to allow roller cams.
__________________
2002 Ford Expedition EB 5.4L. Red on Tan. Full load with leather and sunroof. Gotts mod. K&N air filter.Fresh tune up.
1988 Thunderbird Sport. 5.8L/351W swap.
  #5 (permalink)
Old 03-15-2008, 08:57 PM
I just want it to look and sound a little different. I live in a country town. I want some style and some performance.
  #6 (permalink)
Old 03-16-2008, 12:03 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
What kind of budget do you have to work with?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #7 (permalink)
Old 03-16-2008, 12:05 AM
pretty damn low right now lol. I get about 150 every two weeks. I lost my job due to being sick for a week and seeing my grandma in the hospital 2 months prior to that... long *** story, and I do oddjobs to get what money i do get.
  #8 (permalink)
Old 03-16-2008, 12:11 AM
Blurry94's Avatar
1994 Ford Lightning
First thing you can do is bump the base timing up a few degrees...that's a free mod.
__________________
Matt C.
  #9 (permalink)
Old 03-16-2008, 12:13 AM
how much power/fuel efficency will i get? I think im going to work on fuel efficency first. first thing is new EGR valve. then i plan on going to K&N air filter, headers, dual exhaust.
  #10 (permalink)
Old 04-07-2008, 08:46 PM
greyeagle greyeagle is offline
greyeagle is starting off with a positive reputation.
best bet go to junk yard look for the exhaust manifolds and as well ask for other parts that match up to your model as i am not familiar with the lightning engine but i have a 351w to put in my truck later as i was going that same rout put just the exhaust as well as the heads if i can use my carb on there so good luck ..luv my ford truck
Tags
1993, 351, ford, mods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
