Location of the Diagnostic plug?
Originally Posted by Sabre2th
Sitting in the driver's seat, it's under the dash near your right knee...(OBD II). You don't need a 'special' reader, just one that's advanced enough to be compatable with your system. The ones Autozone uses usually won't work.
Tom
Tom
I agree with Mike. The free or cheap scans won't read the codes you need on the Powerstroke. You need a good scanner to read the codes, and it will cost you a few hundred to get one. You might however, ask on this site, to see if anyone near you has a scanner and would be willing to pull the codes for you.
Is Autoengenuity the only reader that will read PSD codes? That's a lot of $'s for a code reader. I know it's a pretty good system but I'm not going to buy a laptop to be able to use it. Does anyone have a Scangauge II and is it compatible with the PSD? There website says it's compatible with all Ford's. With all the diesels out there, I'm surprised there aren't more diesel code readers available.
You may try looking on ebay for a used programmer (Bully dog, Predator, Superchips) most all of them will read codes, even if you dont want the additional performance offered from them. To go on the inexpensive side look for one that is VIN-locked, that means that the programming has been downloaded to a truck, and cannot be accesed again, but the code reader will still work (in most cases)
Once
Once we pull the codes with Auto Enginuity (just bought it online - waiting for it to arrive) where or how do we interpret what the codes mean?
Is there a list somewhere on line that can tell us?
Ohh - can auto enginuity do anything else besides pull codes?...can you make your own program or alter the standard Ford one in the onboard computer for better performance or anything?
Just seems like a lot of $ for software this just reads codes from another on board computer is all.
I havent got it yet (it may be in my post office box by now - I sure hope so) so haven't had a chance to read up what it does.
Can I for example drive along with it hooked up and monitor my fuel consumption real time while say towing the boat and find the most economical speed?
Just curious what else it will do, besides just pull error codes for me!
For $500 smackers plus air freight - i hopeit has scantilly clad wimmins photos or something! LOL
Cheers and thanks in advance!
