Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-05-2008, 01:36 PM
floydguy is starting off with a positive reputation.
well heres the route im gonna take, i cant really afford the world products heads right now, im not gonna take the risk of trying 4.0 components, im just gonna find a good 2.9 89 or later, im not gonna make things more complicating.
  #17 (permalink)
Old 03-05-2008, 05:48 PM
toddinav is starting off with a positive reputation.
bolt size?
I am in the process or replacing exhaust manifold gaskets on my 2.9 Bronco ii. Does anyone know what kind (size) the exhaust manifold bolts are? Some place said they are metric M8...is that right??
  #18 (permalink)
Old 03-05-2008, 07:10 PM
Quote:
DID YOU BREAK SOME BOLTS TOO?
  #19 (permalink)
Old 03-05-2008, 07:53 PM
Quote:
Yes I did 2 bolts broke so far, i'm spraying PB Blast and letting it soak. The Autozone repair site doesn't say what bolts work for the 2.9 motor...but for the 4.0 they show M8x 46.5 MM bolts. Will those work on a 2.9? I Went to auto parts stores, Muffler shops..no luck, so i went to the local Ford dealership and he quoted me $14.99. Not for a set...PER BOLT!! I'm not paying $150.00 for 10 bolts.
  #20 (permalink)
Old 03-05-2008, 08:19 PM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Just go to the wrecking yard and pull some...might break a few along the way, but the ones that come out should certainly be cheaper than the stealership price...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
  #21 (permalink)
Old 03-05-2008, 10:03 PM
well im not gonna worry about having to easy out my broke off bolts since im junking the heads, by the way i broke all but two bolts, and thats with soaking them in pb blaster, im not even gonna try the pipe to manifold bolts i can work around those.
  #22 (permalink)
Old 03-07-2008, 10:09 PM
so, if i come across a 2.9 merkur in the junkyard, what is the reputation for the heads those 2.9 s?
  #23 (permalink)
Old 03-16-2008, 10:45 PM
nobrandx is starting off with a positive reputation.
I broke bolts on an 86 2.9, I drilled all of the holes out, (after I had to extract the old bolts) and ran a new bolt with nuts and lock washers to secure the exhaust manifolds, it has been 9 years since I hasd done this and the exhaust does not leak and the truck is still on the road.
  #24 (permalink)
Old 03-24-2008, 09:42 PM
Chris102371's Avatar
Chris102371 is starting off with a positive reputation.
I Broke several bolts off on my right side exhaust manifold. I went to the hardware store and got some grade 8 bolts to replace the factory ones. And the 2.9 and 4.0 are not the same motor and the parts will not interchange.
  #25 (permalink)
Old 04-10-2008, 08:54 AM
exhaust manifold bolts............once again!
Quote:
ok, im still working on this truck, im almost done, i pulled 2.9 heads off a 1989 bronco 2, they are good, but while removing them the exhaust manifold bolts broke again, i took nobrandx's approach and drilled all the holes out, i bought stainless steel bolts washers and nuts, to replace, my question for you is how the heck did you get the nuts on the bottom bolts on each manifold, ive got all in on the driver's side except for the middle bottom, and the two last bottom ones on the passengers side, these last three are a real pain, how did you manage?
i am skrewd if i dont get these in, because these remaning holes are no longer threaded!!!!
  #26 (permalink)
Old 05-18-2008, 01:08 PM
fenix1 is starting off with a positive reputation.
Manifold Bolts??? Guess What???
Well, managed to break the Crossover Pipe Bolt heads off and pulled the heads off with the Exhaust Manifold intact, took my Craftsman Broken Bolt Head remover and got the Exh.Man. Bolts out. Had to drill the Crossover out. ANYWAYS, couldn't find any replacement bolts nearby, finally called the nearest Ford Dealer bout 20 miles away. Almost had a coronary when they told me the Exh.Man Bolts were $246 including Tax! I didn't even ask what the Flange Bolts cost. The parts lady was nice enought to tell me the Size, Pitch, and Length of them since there were 3 different lengths. Got on the phone and called a Hardware Supply place in Shreveport(LA) bout 75 miles north of here. When I told the partsman what I needed and he told me they would all be $ 30 I told him, "Ill be there in an hour and a half!!! Same Bolts(Heat Treated)Savings...probably $300 after gas and a Burger w/ fries. Something to think about when it comes to Fasteners.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
