Need help taking out stock air intake tube...
Have ordered the AirRaid ( M.I.T ) intake tube, to replace the stock restrictive unit, and wanted to know how hard is this gonna be to remove? Would I have to to take the whole air box off? Anyone done this, just replacing the intake tube? The AirRaid website says it would take 10-15 minutes to install the intake tube, but how do you get the stock one off? Truck is an 08' F-150 with the 5.4L. If anyone could give detailed instructions it would be greatly appreciated. Not in my budget for the total (CAI) unit so got what I could afford. Thanks, Jeff
Yes there is one screw to remove on the drivers side P.S. reservoir bracket. Then pull the air filter out of the air box and take your fingers and slightly bend the air tube end down to disengage the lock tabs from the air box. The other end of the tube just pulls out of the inner fender, it's held in place by a rubber grommet.
Look in the menu above the forums and find articles. Then select Engine and Intake. Then select what should be the first article, installing a Volant CAI on the Roush project truck. I know that's not what your doing but it has pictures and step by step for removing the stock tube, box, etc. Might help.
thanks for replies, where's this screw or bolt located? Looked at my air box and dont see it. I see bolts holding the air box housing but dont just see 1 bolt see 4. Where's this "menu's" at above the forums? I just dont want to break anything, things seem all plastic and fragile around there. Also which filter should I get? True-Flow, K&N or just use paper filter drop-ins? Whats you performance like with the new tube?
The menu I'm referring to is at top of the web page as you look at this site. You see the words Home - Forums - Galleries - Articles/Specs and so in boxes at top of the page? Click there on Articles - that will take you to a page with a list of categories. Click there on Engine and Intake - that will then open a page shiowing a list of articles nder diferent categories. Right at top of page should be one about installing the Volant CAI on the Roush Project Truck. Open that article and you'll see the pictures.
I installed my Volant using that article as instructions and it was a piece of cake - and I'm about as far fro being mechanically inclined as you can get.
Originally Posted by silver lariat
My understanding, from the article, was the computer is automatically reset by disconnecting and then reconnecting the battery when finished. I did it just because it said to. That's the extent of my knowledge about it.
Best drop in filter - i couldn't tell you. I swapped the entire intake from stock to a Volant CAI. in that case the filter box sits in the fender well and it has a rubber gasket that seals around the stock intake hole. In fact it continues to use that opening as well as one down front where the 'snorkel' fits if you use it. I don't have any experience with just swapping the intake tube and keeping the stock filter box. I'm sure someone else here does.
