fuel rail removal - Ford Truck Enthusiasts Forums
fuel rail removal
Old 02-26-2008, 12:53 PM
NekSiwel NekSiwel is offline
NekSiwel is starting off with a positive reputation.
fuel rail removal
Greetings,
On a '01 5.4L, do I need a special tool to seperate the rail and injectors? I did not want to force it.
Thanks,
Ken
2001 SuperCrew F250
Old 02-27-2008, 11:35 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum
No, the o-rings are all that holds them together. With some wiggling and twisting, they will come apart.
Go to AutoZone or your favorite parts house and get a set of new o-rings if you are reusing the injectors. They are cheap and will keep them from leaking.
Old 02-27-2008, 03:11 PM
Thanks! I have a Timesert tool kit and new boots for the COPs on order.
The # 7 plug blew out. What's the consensus? Just Timesert one or all eight?
Ken
'01 F250 SuperCrew
My girls call it Bo. Short for Bo-hemous.
Old 03-02-2008, 01:23 AM
LxMan1's Avatar
My motto is if it ain't broke, don't fix it. Save the rest until you need them, but that's just the way that I am.
Old 03-05-2008, 02:30 AM
78F150XLT 78F150XLT is offline
78F150XLT is starting off with a positive reputation.
alos be sure when removing the injectors, thats if you are, be very careful when pulling then outta the intake. Try twist them back and forth and not really wiggle them to much beacue you may crack the bottom injector, like the nozzle. I did that on my 5.0, not to pretty....
Old 03-05-2008, 01:35 PM
Thanks to all. Received Time-Sert kit#5553 Monday afternoon. I had the truck running just before nightfall! It's a little scary but I took my time and checked/cleaned the cutting tools often. Jimmy, I'm with you (IIAB,DFI). My go/no go plan was; if the spark plug will hold 13ft-lbs of torque I would leave it be.
The Time-sert kit is top notch quality. I will be putting it on eBay soon.
I replaced the O-rings on the injectors, thanks again.
Next, it looks like there are some ball joints in my near future.
Thanks for the help, Ken
http://neksiwel.20m.com/
2001 F250 CrewCab "Bo", 127K miles
I still can't believe I have only owned this truck two weeks and already I'm putting in a Time-Sert.
What years bed fit kdv 1999 - 2003 7.3L Power Stroke Diesel 10 10-21-2015 04:06 PM
Facts & Figures from Ken's Almanac ken1mod Aerostar 23 03-10-2015 06:39 PM
1966 stepside papawfalcon 1961 - 1966 F-100 & Larger F-Series Trucks 2 09-09-2013 08:13 PM
New to Texas and this damn single rail rug The_Builder Texas Chapter 3 07-17-2013 12:53 AM
Chip for 351W and Where do I find my ECU code? FTE Ken Computer Chips & Tuners 12 01-31-2003 12:57 AM
Tags
2001, 2oo1, 46, 54, back, f150, ford, fuel, injector, put, rail, rails, removal, remove, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
