Coolant smell, windows fog up - Ford Truck Enthusiasts Forums
Old 02-26-2008, 09:57 AM
KART77 KART77 is offline
KART77 is starting off with a positive reputation.
I own a 1999 ford f-150 4.6 liter 4x4...that i just recently flushed the cooling system due to the heater not blowing very warm air......
every since i flushed the system, whenever i turn the heat on, i get a strong smell of anti-freeze, and my windows fog up so bad that i have to wipe thewm off with a cloth. I have looked for a leak, cannot find one. I have checked inside floorboards , all are dry...... could this be the heater core, and why would it only do this after flushing? the engine never overheats......
Old 02-26-2008, 11:16 AM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
More than likely.
Quote:
There's been a lot of discussion about replacing heater cores, suggest you do a search. These aluminum cores commonly fail b/c of internal corrosion & flushing can open up pin holes. Failure to change antifreeze is implicated in the corrosion.
Old 02-26-2008, 11:19 AM
metal13x metal13x is offline
metal13x is starting off with a positive reputation.
just dont breath that stuff in, i cant imagine it is good for you
Old 02-26-2008, 11:23 AM
jgoose jgoose is offline
jgoose is starting off with a positive reputation.
Quote:
My 85 f150 was pretty bad about the heater core going out. Driving around and breathing that anti-freeze in gave me the worse headaches ever. When it would go out it did the same thing, it cause the inside of the windshield to fog over. It also leaves a film on the inside.
Old 02-26-2008, 11:44 AM
Archer131 Archer131 is offline
Archer131 is starting off with a positive reputation.
Definatley the heater core... just did mine on a '97 f150....not hard...not fun...pland on spending 6 hours doing it yourself.
Old 02-26-2008, 12:43 PM
Thanks For The Reply's Guys.......
Guess I'll Be Replacing The Core Come This W/e......
Old 02-26-2008, 01:23 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
This might help. Good luck!
http://my.voyager.net/~sscully/F-150...50_Exp_002.doc
Old 02-26-2008, 04:35 PM
RJB1's Avatar
RJB1 RJB1 is offline
RJB1 is starting off with a positive reputation.
Definately the heater core. $100 in parts and 6 to 8 hours of labor. Not hard just time consuming... Just did one 3 months ago.
Old 02-27-2008, 03:19 AM
fdrf150 fdrf150 is offline
fdrf150 is starting off with a positive reputation.
Talking
LOL....Ah, the dumb stuff we do when we are young. Reminds me of the times me and my buddies would drive down to see Jimmy Buffet in Cincinnati and the car leaked so much carbon monoxide in the cab that we had to hang our heads out the window the whole trip. Who would have thought that was bad for you?...
Can a Heater core slowly go bad Dlasure2 1997 - 2003 F150 5 12-06-2013 10:52 AM
Dang heater core! lance65 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-27-2013 11:32 AM
Heater Core grip1968 1997-2006 Expedition & Navigator 4 10-25-2013 08:11 AM
Windshield Fogging Dofunny 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-07-2004 12:19 AM
Heavy window fogging, steam from heater vents?? riverguides Cooling, Heating, Ventilation & A/C 4 11-03-2002 05:14 AM
Tags
1997, 2001, 2002, 89, antifreeze, coolant, econoline, f150, f250, fog, fogging, ford, mustang, smell, truck, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
