I have a 390 that has a lot of work done to it and completly rebuilt.
My question is i want to drop it in a 78 f150 4 wheel drive. c6 ,posi rear end.
will my 390 bolt right in to the transmission. the 78 has a 400 in it atleast that is what the seller told me. motor mounts im not worried about. the 390 came out of a 71 f100 with a manual transmission. the new truck (''78) has a automatic tranny. so my next question is what about the flywheel. any help would be great.
i know a c6 will hook up to a 390 but can i pull out the 400 and drop the 390 in its place.. will the c6 that is bolted up to the 400 hook up to my 390. not sure about the bolt pattern. i know there is a c6 for a bigblock and a small block.
the 351/400M's are BB bolt patterns for trannys. and i am not 100% sure if the motor mounts are the same. i would have to lean more twords yes....???? but im only 60 percent sure.
but the 390 will bolt right up to the C-6 that you have.
Mitch
i believe that the 390 is a big block also. the c6 only has one bolt pattern but in differ sizes small and big block. i had a c4 on the 390 i will be pulling the motor out of the 78 with 400 this weekend and i will let u know for sure if it bolts up.
