Rust repair on 64 F250 Styleside Bed - Ford Truck Enthusiasts Forums
Old 02-26-2008, 03:09 AM
DShuler DShuler is offline
DShuler is starting off with a positive reputation.
I am working on a 1964 F250, mostly rust free with the exception of the bed. The truck has the styleside steel bed and it is rusted through where the bottom bed panel meets the front panel. In some places there is as much as 2 inches of the bottom panel rusted away. The rest of the bed appears to be solid.
I am looking for suggestions or ideas for economic repair options or sources for steel panels designed for this type of repair. If you have completed a similar repair please share your experience.
Thank you
Dan
Old 02-26-2008, 12:13 PM
1964_mezajd 1964_mezajd is offline
1964_mezajd is starting off with a positive reputation.
Dan, I've been struggling w/the same question for a while now but have not found repair panels for the truck bed. My '64 has similar areas of rust as yours and have not yet repaired it. I read a post some time ago that one of the guys on this forum was looking into asking a manufacturer for custom making some replacement panel. Others have suggested looking for a donor truck and cutting out panels as needed. I've thought of buying repair bed panel for other years and see if it will work but after looking at different catalogs and web sites, don't think they will work.
Old 02-26-2008, 01:32 PM
camaroneil camaroneil is offline
camaroneil is starting off with a positive reputation.
i'm watching this thread with great interest,
mine is only JUST rusted thru in a few places but i'd like to repair it,
neil
Old 02-26-2008, 03:35 PM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to behold
I don't think there is a single truck out there, from that era, that doesn't have rust in that location. The area up front was easy to fill with debris under the high ribs and kept water from draining through and out. Mine has an issue at the front drivers corner. The rest was pretty much ok and I cleaned it all out and coated it heavily with Eastwoods Rust Converter top and bottom. Still there are those two small holes that need to be replaced with something...
Old 02-26-2008, 07:26 PM
Hakk Hakk is offline
Hakk is new and has a neutral reputation at this point.
I bought the repair panels from LMC and I sent them back. IMO they were JUNK. They looked nothing like the actual bed.
My bed is rusty and I've decided to buy an 8 foot bed from anything I can find at a local junkyard and make it work. A local place estimated $200-300 for an 8 foot bed.
To just repair an edge IMO you should just buy some steel from a local shop and weld it up!
Old 02-26-2008, 08:07 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Bookmarked a couple of FTE member pic's who reconditioned the bed on their trucks. Hopefully of some help. Don't suspect member would have problem w/ email if have any questions. May also want to run search topic has come up on number of occasions.
http://www.ford-trucks.com/user_gall...&albumid=30574
http://www.ford-trucks.com/user_gall...10&albumid=206
dave
Old 02-26-2008, 10:06 PM
dave
Dave, those albums were helpful. How can I get in touch with these guys?
Old 02-26-2008, 11:01 PM
Hey, better late than never, Welcome to FTE. It's a good point, in the future I will have to make note in bookmark field who the author is. Ran a search under 'bed restoration, or bed repair' and came up with CustomCab4x4 as the member who posted pic's under 'rust repair for 64 F250'. Will try and locate member who posted the other, with any luck may look familiar to another member, better yet, may get lucky and the member who posted the pic's will respond.
Customcab4x4:'rust repair on 64 F250'
http://www.ford-trucks.com/forums/se...member&u=18810
dave
Old 03-09-2008, 03:29 PM
Good news! I found to good beds no rust in the front. I'm going to have them sand blasted and sealed and painted. Wimbledon white was the original color. Also considering a spray in liner. Any suggestions on product. Also I have two beds with rust in the front corner if there is any interest.
Old 06-13-2014, 12:56 PM
travlinsam travlinsam is offline
travlinsam is starting off with a positive reputation.
I have the same exact problem with my '66 F250 and have been mulling over what to do. I don't have a lot of money to do the repair or the facilities. I also don't want to screw up the truck with a half *** repair. Other than the rust at the front part of the bed (where the vertical panel behind the cab connects with the bed) the bed is really solid.
Thoughts?
Old 06-13-2014, 01:36 PM
svolpone's Avatar
svolpone svolpone is offline
svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.
that's a beautiful truck
Old 06-13-2014, 08:34 PM
Thanks...she really solid except for that rot at the one end of the bed. I love slicks...
Old 06-14-2014, 01:26 AM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab Jeff64F100CrewCab is offline
Jeff64F100CrewCab is starting off with a positive reputation.
When this started to happen in my truck, many years ago, dad drilled a hole at the front end of each trough. At the far edges ahead of the wheel arches there is come metal missing however. I now park my truck with the front end a couple of inches high to aid in draining the bed and the rain gutters. Eventually I'll get to that area...
Converting from steel to wood bed? StatikPulse 1957 - 1960 F100 & Larger F-Series Trucks 4 01-28-2015 12:51 AM
1968 Ford f100 Sacrifice 1967 - 1972 F-100 & Larger F-Series Trucks 1 12-28-2014 09:47 AM
Ford Styleside Bed End Patch Panels 1957-66 mfire138 Ford Truck Parts for Sale 0 08-06-2014 02:52 PM
2000 f250 crewcab rusty wheel well solution Andy's Beast 1999 to 2016 Super Duty 4 03-13-2012 07:55 PM
1967 F100 Styleside bed parts thorswhisper 1967 - 1972 F-100 & Larger F-Series Trucks 5 02-22-2012 06:43 PM
Tags
64, bed, f150, fix, ford, panel, panels, pickup, repair, repairing, replacement, rust, rusted, truck, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
