4X4 Light Blinking and ABS light on - Page 2 - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 11-21-2014, 12:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Browse all: 4WD Guides
Print Wikipost
Old 12-01-2011, 09:11 AM
cathysmom cathysmom is offline
cathysmom is starting off with a positive reputation.
Thanks! Dropped it off to the mechanic last night...and trust me when I say spending $325 is alot cheaper then what I would end up spending if either me or my husband ever tried to correct it!
Old 12-01-2011, 02:57 PM
rickfar rickfar is offline
rickfar is starting off with a positive reputation.
Quote:
I understand what you are saying
Old 12-01-2011, 03:44 PM
It was indeed the other side...this time it was only $251...Now lets hope the back ones stay together!!
Old 12-06-2011, 09:58 AM
mdsample99 mdsample99 is offline
mdsample99 is starting off with a positive reputation.
Any Ideas!!!
I have a 2007 Ford Escape Hybrid. Two weeks ago my abs light and and 4x4 light came on. Took it to get repaired and I had a bad tone ring so they replaced the halfshaft. It seemed to have fixed it however a week later both lights came back on. For a day or two the lights would go on and off then as I was backing out one day it made a loud pop. It then said my 4x4 was disabled and to get it serviced. The next day when I went to get it repaired both lights were off and after driving about half way there they came back on. The shop looked at it and they think it may be a bad sensor but they arent sure. They didnt have the part and I am currently driving it waiting on them to get the part in and the mechanic assured me it is safe to drive and I wont damage anything else. I just want to know if anyone else has experienced this problem. Or if anyone has any ideas because the loud pop has become more frequent and it is now making a noise while driving and a rubbing noise like the brakes are bad which they arent because I checked them. Does anyone have any ideas???
Old 12-23-2011, 05:53 PM
DaveTV DaveTV is offline
DaveTV is starting off with a positive reputation.
This is happening to my 2005 Escape with 89k - I have not seen or noticed any ill effects, so for the moment I will leave it be. What is the symptoms of a bad "tone ring" other than the ABS/4x4 sensor lights on the dashboard ?
Old 12-23-2011, 06:13 PM
Quote:
You could get a real hard pedal and the abs could kick in on dry road and at low speed and normal braking situations
Old 05-21-2012, 06:26 PM
Saugs Saugs is offline
Saugs is starting off with a positive reputation.
also abs light and flashing 4wd with some grinding in revere
  1. 2007 Ford Escape with nearly constant abs, flashing 4wd and occasional grinding in reverse (have no idea why) had it checked at local garage and error codes c1233 and U2023. Mechanic told me U codes had to be done at dealer. Replaced the ABS module about a year ago (this part was recalled in 2007 on earlier models and I asked ford if my car had the same module and they wouldnt tell me) Seems the problem takes a few years to surface so I saved that part and the bill waiting for the recal) based on the posts here sounds like the new problem Im experiencing is not uncommon. Does anyone have uodates to their issues? Do I have to go to the dealer for a ucode? Am I looking at a sensor? a tone ring? both? Any idea on cost at a dealer?
Old 05-26-2012, 12:06 AM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
I just replaced the pass. tone ring on my Moms 2005 Escape.It is less then a hour job and tone ring from Ford was $6.70.The guy at the dealer said the rear tone rings don't fail often. Go to this site and you can check on recalls. Recall Notices| Ford, Lincoln & Mercury Owners | Official Ford Owner Site
Old 07-30-2012, 09:43 AM
Becca Louise Cogdill Becca Louise Cogdill is offline
Becca Louise Cogdill is starting off with a positive reputation.
My ABS light stays solid and my 4x4 light blinks every now and then but I hear a grinding-type noise sometimes when I turn my wheel while driving. Also, when I break and take a hard turn (both left and right) sometimes I will hear grinding or it feels like my breaks arent working like they will work then stop like they arent making a connection. I'm not sure if this is the ABS Tone Rings as well? Has anyone else experienced this???
Old 08-02-2012, 09:13 AM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
Quote:
More then likely its the tone ring. It's possible the ring is rubbing the abs sensor. There really close to begin with. Look under the front end at the tone rings...it should be obvious if there cracked.
Also your brakes will act up too. Our 06' did when we had cracked rings. I heard about it every day from my wife on how crappy her escape was driving.
Old 08-02-2012, 11:17 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
When the tone ring on my 07 broke earlier this year, I didn't have any change in braking performance.
Old 08-04-2012, 10:16 AM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
What I did: If you slide the tone ring in place with out the paper it will slip on/off and spin easy. I took small pieces of paper about an inch wide and 3 inches long. I test fitted them under the tone ring making it shorter until I had a snug fit without opening the gap at the break. Then slide it out of place clean the area the ring sits on and apply a small layer of RTV. I used red RTV and placed the paper on the RTV and then a layer on the paper. Slid the ring in place and let it dry for about 15 minutes while I cleaned up.
I went for a drive and the light never came on until the other side broke. It had the same repair.
Rod
  #28
Old 02-12-2014, 10:40 PM
Hate to bump an old thread, but I am having the same issue ane suspect the ABS tone ring. My question is, how do I know which side is causing the issue? THX
  #29
Old 02-12-2014, 11:38 PM
Visual exam. It will be obvious if the ring has failed completely.
  #30
Old 06-25-2015, 10:09 AM
CFloyd2963 CFloyd2963 is offline
CFloyd2963 is starting off with a positive reputation.
Exclamation ABS/4wd light on and flashing.
I'm at a loss what to replace next on my Mercury Mariner 2007. My ABS/4wd drive light is on and flashing, I have already replaced sensor on passenger front. Anybody with a suggestion?
ABS light on constant after axle swap Taylortd Excursion - King of SUVs 0 10-13-2015 10:35 PM
Blinking 4x4 light briangelc Expedition & Navigator 8 03-02-2014 11:08 PM
ABS light is on and 4x4 light blinks Branny08 Escape & Escape Hybrid 6 04-02-2012 08:02 PM
abs light blinking on 1995 f-150 tomnoajo Brakes, Steering, Suspension, Tires, & Wheels 0 01-24-2005 03:47 PM
ABS blink code rgb1963 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-30-2001 08:24 PM
Tags
2005, 4x4, abs, blinking, code, escape, flashes, flashing, ford, issue, light, ring, sensor, times, u2023
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
