Transmission question
Old 02-25-2008, 10:22 PM
69 F-350's Avatar
69 F-350
69 F-350 is offline
I have a 3 spee Od out of a 1985 F-150 2wd . I was wanting to put it behind a Onan 6AT diesel . The engine came out of a P-350 bread truck . I runs great . I was wanting to know what the gear ratios are on the transmission . The engine has about 135 ftlbs of torque . The tranny was behind a 300 6 cyl . Iam trying to find out if this tranny will work or will I have to go to a N<!-- -->WC or TKO 5 speed . All help is greatly appreciated .
Old 02-26-2008, 10:00 AM
subs1000w's Avatar
subs1000w
subs1000w is offline
i really have no idea but what trans was behind the onan in the bread truck
if it was a ford trans it should work but it could of been a chevy trans in which case you need a chevy trans
Old 02-27-2008, 03:42 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,585 Likes on 1,292 Posts
The Ford od trans probably had 3.25/1.92/1/.78
http://www.gearzone.net/toploader.html
Pretty wide spread between 2nd and 3rd.
I'd look for a 5 speed with 1:1 5th, a Clark perhaps.
Old 02-27-2008, 08:10 PM
69 F-350's Avatar
69 F-350
69 F-350 is offline
Thanks for the help guys . I went out to the garage and wrote down some numbers off of the transmission . The top has RF-E5TR-7222and the case has the number RF-E5TR-7006-AA, the tailshaft has RF E4TR-7A040-AA.
The tag on the tranny has(RTS ABI mf 10 )AND BELOW THAT( E4 TR BA 0327) . Can anyone decode the tansmission from these numbers.I don't like guessing at what I have . The main problem I have in the installation of this transmission is the T-19 and Np435 I have hit the crossmember of the truck . The truck I am putting this combo in is a 1954 International short bed pickup . If the cab was made like my 56 ford truck this tranny problem would not exist .If I can't use this tranny does anyone have a suggestion of another tranny that has the shifter in the center or more toward the rear of the case that would hold up to the diesel .The engine has 120 hp and 135 ftlbs of torque.
Old 02-27-2008, 09:53 PM
85e150's Avatar
85e150
Thought you knew what you had...a Ford toploader overdrive. Does yours have the shifter coming out the top, on a rail along side the top, or side mounted with levers?
First ones up here:
http://www.motivegear.com/tech_info/...nny_guide.html
These were put behind 300 sixes with 250lb ft of torque, so you're ok there. The ratios aren't great, but with that amount of power, you've got all day to get through each gear anyway.....
Old 02-27-2008, 10:09 PM
69 F-350's Avatar
69 F-350
69 F-350 is offline
My shifter comes out of the top . And the shifter forks are on the left side of the tranny inside .( facing tranny form the tail shaft side )
Old 09-24-2016, 09:53 PM
willy9453's Avatar
willy9453
willy9453 is offline
You have the same trans that I put in my 73 F100....It's a Tremec T170 RTS
Ryanwith
11-25-2017 06:22 PM
Ryanwith
New Member Introductions
11-25-2017 09:11 AM
OrCwby
General Diesel Discussion
01-21-2017 02:49 PM
RRRAVEN
6.2L V8
18
12-03-2016 08:25 AM
82fordowner
06-21-2016 12:29 PM
Quick Reply: Transmission question
