throttle body spacer.
on
1 Post
A friend of mine put a TB spacer on and he says he can definitely feel better throttle response since the TB spacer. As I understand it is supposed to help atomize the fuel and the additional O2 from the CAI would effectively improve power and fuel economy. He already had the CAI and both fit fine.
Ever heard of the stoichiometric ratio?
http://en.wikipedia.org/wiki/Air-fuel_ratio
http://moodle.student.cnwl.ac.uk/moo...tricratio.html
http://www.crypton.co.za/Tto%20know/Emissions/afr.html
http://www.victorylanedata.com/docum...E%20Manual.pdf
I have a Poweraid throttle body spacer on my truck. And yes it does make a whistle. But if you have the radio at a STOCK NUMBER 10 w/out the speed sensor...you can't hear it. But you wont get anything out of it unless you are above 2k on the Tach. Or at least when I travel I've knotice about from 2,300-2,500 is where I start to get the better gas milage.
I'm sure it also makes a difference if you have a 4.6 or 5.4.
All I have to say is that if you dont get an aftermarket exhaust you won't see any significant changes. Think about it you are allowing to "BREATHE" but what about "EXHALE?"
