Quick Question
Had a vibration problem that turned out to be the tire itself. The belt in it was broke. Found that out after checking the rim and balancing. If you hit something hard like a pot hole you can damange the tire and it can cause vibration. Do you feel a vibration or just hear a vibration noise?
i have had two sets of tires on the truck, right now i have a bfg all terrain. It is a 4x4 and i have auto locking hubs. I have replaced the u joints in the rear driveshaft. I did not replace the carrier bearing yet though...because my truck is extended cab i have a carrier bearing... i have done nothing with the front end. When i got the new tires i did get them balanced and the truck was supposedly alligned, personally i think they did a crappy job...i went in there a half hr before they closed on a friday afternoon and i dont think they gave it the time of day.
