door chim
Here's a copy of a post I made after doing mine. WOrked on my 2008 also. And as to the above post, I BELIEVE HE'S SPEAKING OF THE SEATBELT CHIME. tHERE ARE NO INSTRUCTONS in the manual for the door chime.
Robber, looks like your topic got side tracked. I listed the post you have the like to. and here is a paste of another I did.
clinthman
I have an 06 and found out it is different. Remove the panel below the steering column. You will see two plugs but stay away from them. Along the left side of these plugs, you will see two fairly thick groups of wire. In checking each bundle and you will find a black wire with a pink stripe. This will be you wire. As I only wanted it disabled at certain times, I bought a small toggle switch and mounted it on the piece of plastic just to the right of the gas peddle. You might see a pink wire with a black stripe which goes to one on these plugs, stay away from that wire.
__________________
clinthman
__________________
clinthman
__________________
clinthman
__________________
AThank you for your reply. I already disabled the seat belt chim. There is nothing in the manual about the key alarm(when the key is in the ignition and door open). Yesterday I pulled the dash apart and still couldnt find this alarm. Idont need to totally diable it. I would be happy just quieting it down a bit. If anybody knows how to get to this thing please let me know. Thanks Also I am not seeing a blck wire with pink on it.
Yes, you can just cap it off as it does nothing else. One note, when you cut the wire, don't have the key in the ignition. I did on my 08 and just as I cut the wire, the cutters touched some metal under the dash and blew a fuse to all kind of stuff. Spent a ton of time trying to find the fuse. Turns out is was one of those square, clear topped fuses in the pass. kick panel box. Missed it the first time looking for it as it was tough to see the burned are. Go to it.
