well for rite now im just gettin the tune and in a week or so affter a lil more research im guna get the pulley ...but the more miles i put on it , it seems faster...that saleen charger needs break in time it seems...i have 520 on mine now and its already faster then when i first got it
A custom tune will help, provided the correct person tunes it. It doesn't leave a signature --- some claim it does. The PCM is supposed to have a flash counter but on these trucks its not incremented.
__________________
Ken Payne
Gone Fishing...
LACK OF PLANNING ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
2006 Roush F150 Project: Roush Supercharger, Troyer & My Tuning, 9lb pulley, Level 10 Trans, E-Fans, Oil Separator, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Headlights & Taillights, Retrax Retractable Tonneau & more.
2004 F250 King Ranch Crewcab 4x4 6.0L PSD project: DP-Tuner Tuning and MBRP Stainless Dual Exhaust.
2000 Ranger Supercab XLT 3.0 V6 project: Bright Box, Mac Intake, Tonneau, my tuning.
RIP: 1967 & 1975 F100, looking for a 66 F100
Has it gotten colder since you got it, or a humidity change? Air temp and humidity play a huge part with boosted engines. In the summer it really sucks compared to winter power!
__________________
Ken Payne
Gone Fishing...
FTE Ken, if I get a custom tune from Troyer performance, Can I use the same tune for both trucks? Also, I already have an SCT II from my previous truck, do you know if troyer will just sell the tunes? Thanks
Tuners are VIN locked to vehicles. Plus the Roush and Saleen are completely different setups with completely different tunes. Troyer can reprogram the existing SCT, but you'll need to buy a 2nd one for the other truck.
__________________
Ken Payne
Gone Fishing...
GOT MY SCT X2 TODAY! THE TRUCK RIPS NOW...BUT OF COURSE IM STILL LOOKING FOR MORE POWER! THINKIN BOUT GETTIN THAT UNDERDRIVE PULLEY...HOW MUCH EXTRA BOOST DO YOU GUYS THINK ILL BE GETTIN IF I RUN A 2LBer ...
You run boost pulleys. Boost pulleys turn the supercharger faster. Underdrive pulleys (used on naturally aspirated trucks) turn the accessories slower. You don't run underdrive pulleys with a supercharger.
You should have gotten the pulley first, because you're going to need to get a new set of tunes for the SCT to use the pulley with the blower. Did Troyer do the tunes for you? He can probably redo them, but I'd get him to do it know, rather than waiting for it and paying him a 2nd time!
__________________
Ken Payne
Gone Fishing...
no i got the tune from JDM engineering from Jim jr... he said that if i run a smaller pulley like a 3.2 or so ill need a new MAM and so he basically wont sell me a smaller pulley without trying to get me to buy his mass air meter and cold air kit and some other bull ****....i talked to troyer and he said that stock MAM will be fine until i start gettin into the 550 hp range... not sure how small to go on the sc pulley tho
You should have listened to Troyer (and the advice here), and got him to tune it. He's tuned more F150s than anyone in the country, bar none.
JDM is giving you bad advice. You shouldn't go with a smaller SC pulley. This can cause belt slippage due to less surface area. You should go with a larger lower pulley to increase boost -- it will increase surface area. You don't need a new MAF or anything else with the pulley swap, just the proper tune.
__________________
Ken Payne
Gone Fishing...
Incorrect. He should NOT go 4lbs over on the 3-valve 5.4. You can do that on the 2 valve 5.4 on the Lightning, but not on these newer 5.4 3-valve V8s. He needs to stick with 2 lbs more boost than the stock boost level, if longevity is of any concern.
__________________
Ken Payne
Gone Fishing...
