Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-24-2008, 04:49 PM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Installing HVAC on 60, Compressor and Alternator
We started the process of adding a new heater/AC to our 60. We bought a kit from Classic Auto Air. $1265 delivered to the house. First thing we had to remove lots of stuff, radiator, battery tray, alternator, etc. Then we worked on fitting up the compressor and relocating the alternator. Here are a couple before and after shots. BTW the engine is a 292 Y-block.
__________________
Walston
http://bigjohnstractor.com/
  #2 (permalink)
Old 02-24-2008, 04:53 PM
Walston's Avatar
1960 Ford F-100
The mounting brackets worked pretty well, although I had to adjust the spacers a little to get everything lined up properly. I had to grind a little off two of them to get proper clearance, overall it worked well and I like having the alternator on top away from splashing water. Here is the mounting kit Classic Air supplies, plus where I had to grind.
__________________
Walston
  #3 (permalink)
Old 02-24-2008, 04:57 PM
Walston's Avatar
1960 Ford F-100
Here is a couple shots of most of the stuff that comes in the kit. There is also a shorter glove box that comes with it and a wiring harness. The blower assemble is a little larger than the original so the glove box loses a little space.
We will keep taking pictures and eventually put together a gallery that details the installation.
__________________
Walston
  #4 (permalink)
Old 02-24-2008, 09:40 PM
cmoritz cmoritz is offline
Garage is empty, add now
cmoritz is gaining momentum as a positive member of FTE.
That is a Great uprade Walston!! Cruise time will be so much more enjoyable! Keep us posted on the progress, I'm real interested how you do the vent install. Good Luck!!
__________________
MERTZ
  #5 (permalink)
Old 02-25-2008, 10:01 AM
tacson's Avatar
tacson tacson is offline
1955 Ford F-100
tacson has a good reputation on FTE.tacson has a good reputation on FTE.
Definitely keep us posted how she performs
__________________
DONALD
1955 Ford F100 with a 5.0 EFI/AOD
  #6 (permalink)
Old 02-25-2008, 01:25 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm is a name known to allbobbytnm is a name known to allbobbytnm is a name known to allbobbytnm is a name known to allbobbytnm is a name known to allbobbytnm is a name known to all
Great pics, good details.
this has all the makings for a great tech article.
Bobby
__________________
...Someday our foes may win...
...but NOT today!!
1949 F1, 500ci Caddy
1967 Jeepster Commando
1965 Falcon
1994 Harley Road King
  #7 (permalink)
Old 02-25-2008, 04:38 PM
Walston's Avatar
1960 Ford F-100
Bobby
I agree, but it sure takes a long time to get them published, so first I will make sure it is at least we documented in my gallery.
__________________
Walston
  #8 (permalink)
Old 02-25-2008, 06:14 PM
DR Smith's Avatar
DR Smith DR Smith is offline
1954 Ford F-100
DR Smith is gaining momentum as a positive member of FTE.
It looks like a very good job,althought I am a little concerned with the alt mountting.It looks like you have a bolt on the top mount that goes threw the alt with a nut but no rear mount.I had mine like that and became worried that vibration might break the bolt.As this mostly happens when your on the road,I refabracated a rear mount to add more strenght.It will probalbly be ok ,Just something to think about,
  #9 (permalink)
Old 02-25-2008, 06:31 PM
Walston's Avatar
1960 Ford F-100
There is a rear mount, it is difficult to see it in the photo. It is the one below. It mounts through the 2 bolts in the timing cover. I have it taken apart right now for painting of the brackets, once re-assembled I'll show it from both sides.
__________________
Walston
Tags
compressor, hvac, installing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
