FuelmisterII????
Originally Posted by TchTchr
I believe the correct spelling is FuelMeister. I checked their website. The system looks pretty slick and foolproof. I would love to make the bio-diesel instead running SVO, but storage is my problem. If I had room, I'd be making the bio-diesel.
Just from reading, both have their advantages and dis-advantages. WVO you don't have to use something like methanol to create the fuel. With true B100 you don't have to wait for the motor to warm up before you start to burn it. Personally, I like the idea of WVO....less chance of a fire while prepping the fuel (filtering and de-water)....but to each their own. When using waste cooking oil/grease for the feed stock...both will cause the truck's exhaust to smell like the fryer they came from....so the "pollution" could get you in trouble with Weight Watchers police.
True - there is a chance of fire when dealing with methanol. I know a guy who burned a shed making bio. I'm sure the insurance company would not pay out either if you burned your house down. If I lived on a farm with a disposable shed, I'd make bio. As it is though, I'm perfectly happy with running wvo.
Originally Posted by Phydeaux88
BD is safer for your engine than WVO.
If you do the mods to your truck and follow startup/shutdown protocols faithfully you can reduce the risk but not eliminate it.
Originally Posted by Gun-Driver
What I like about Bio is that I dont need an extra tank, fuel lines(more things that can leak) or an extra fuel pump. You just pour it in the fuel tank. In the winter all you have to do is blend it with regular diesel, you don't have to worry about heating the extra tank.
Some say you can.
I dont believe they will stay blended.
About this time I finally came up with the very primitive Vegistroke idea with two completely seperate fuel systems. Immediately my roadside breakdowns were done. Still had issues with the WVO stuff, but no more being stuck when it went wrong. Took a LONG time to get the pumps figured out. But for a period everything was going well with the WVO stuff, so getting greedy, I started mixing WVO and diesel in my main tank again. And while on a road trip, I plugged my stock filter. . Again. And that was the last time anything other than normal #2 diesel has been pumped into my diesel tank. Not worth the headaches that i have had with it.
So, to finally answer the question of seperating, No, Diesel and WVO will not seperate. Back when I started all of this I mixed 50/50 #2/WVO, put it in a sealed container on my shop counter, and there it sat for the next 6 months. Never seperated. It did however start to grow. I added some anti-microbial to it and the growth stopped.
Just because you do not see a clear line of seperation does not mean seperation didnt occur along a gradient.
VO and #2 are partially miscible but the large difference in molecular size makes it almost impossible to get complete blending that wont seperate to some extent.
With two partially miscible liquids that have been blended and allowed to stand undisturbed for some time the very top layer will be somthing like 90% of the least dense and 10% most dense. as you move down thru the liquid column the percentages will gradually change with the more dense increasing and the less dense decreasing untill the very bottom where the percentages may well be reversed. If the two liquids are similar in color you may not be able to detect this change but your engine can.
Correct me if I wrong...but doesn't VO put undue stress on the OEM fuel pump? I vaguely remember reading somewhere that SVO causes the pump to over heat trying to pump it when it's below 120 degrees because of the thickness of the oil/fuel. Warm the oil up and the pump in the tank doesn't get the cooling effect from the fuel since it's warm than the pump. Maybe it was on another forum related to using VO for a fuel...thus the reason two tank WVO/SVO are the way to go. I can't remember if the Fords still have the pump in the tank or not.
