Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-23-2008, 10:35 PM
EXPI EXPI is offline
Garage is empty, add now
EXPI is starting off with a positive reputation.
Better suspension on 07 Expedition
Besides replacing the Contijunk tires on my 4x2 07 EB (has tow package), I have been considering putting a new spring set in to reduce height by about 2 inches (in order to lower cg for stability purposes). I would also like to reduce the boat wallow when turning but not impact ride quality - too much.
Any ideas or does anyone know of a good supplier of a spring kit that won't make it ride like a truck (no pun intended - ??)?
(this is duplicate of my post on the other Expedition site as I am a nubie and did not see this site for 07/08's)
btw - a response on that list reported less wallow with stiffer torsion bar.
  #2 (permalink)
Old 02-27-2008, 03:51 PM
Tmod700 Tmod700 is offline
Tmod700 is starting off with a positive reputation.
I put the stiffer bars from Hellwig on my 08 4x4 and it made a very nice improvement. Very stable in the corners and that is with just the sway bar addition.
I memory serves me correct the Hellwig front is 1.5" and the rear is 21mm.
The stock bars should be 1.375" front and 19mm rear so you do get a considerably beefier bar.
Took me about 20 minutes to install these suckers and no alignment needed.
Tmod
  #3 (permalink)
Old 02-28-2008, 11:35 PM
Thanks for the reply!
Did the ride get much stiffer from the beefer sway bars or just less roll when cornering?
  #4 (permalink)
Old 02-29-2008, 10:06 AM
It didn't get any rougher when traveling down the road. It will be stiffer when you hit a bump with only one tire or side as the sway bar is being used at that point.
The new bar will keep it tighter when cornering.
Tmod
  #5 (permalink)
Old 03-01-2008, 11:26 PM
10-4. Thanks very much for the information This sounds like the best option for me so far; that 20 minute install thing really caught my eye.
Thanks, again!
Tags
2007, expedition, ford, stiffen, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
