Cab Mounts: - Ford Truck Enthusiasts Forums
Cab Mounts:
Old 02-23-2008, 09:35 PM
leonharu's Avatar
leonharu leonharu is offline
leonharu is starting off with a positive reputation.
Cab Mounts:
Can I change the cab mounts on my 1952 F-1 without taking a lot of things loose or off?What is the best way to go at this?My passenger door does not seem to line up very good when you shut it.Does this maybe have something to do with worn cab mounts?
Old 02-23-2008, 11:15 PM
LEckart's Avatar
LEckart LEckart is offline
LEckart is starting off with a positive reputation.
I would guess the misalignment on the doors is due to worn hinge pins more than cab mounts so check both. You should be able to change the mounts without taking anything off other than the worn out items at the connection points unless I'm missing something in what you are asking. Get a shop manual for the 52 if you don't have one.
Old 02-23-2008, 11:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Which cab mounts, front, middle, or rear? The rears are a snap, just jack up the cab a little on the rear cab crossmember. The front ones you have to be a little more careful jacking because you are trying to lift the inner fenders and front fenders, too.
Old 02-24-2008, 10:23 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
If you are looking to install in one piece the complete cab corner available from several of the venders imho I would say not without having the cab off the frame. I replaced both of my front corners plus floors. If I remember correctly it was easier to replace the cab corner and portions of the floor together. If the cab corner is bad at least part of the floor, that which is sandwiched under the cab corner, is most likely bad also. I am sure that some fabricated non original fix of the cab corners could be done but if you want it pretty much original using the cab corners being sold I think you will want the cab off the frame.Maybe somebody else will chime in that has done it with the cab mostly in position on the frame.
Old 02-24-2008, 10:29 AM
LEckart's Avatar
Me thinks I don't understand the question here. Is the question regarding the replacement of sheetmetal and anchor point or just the fasteners/rubber mounts, etc. at these points? If the sheetmetal, then disregard my previous comment because you will have to do more than I stated.
Old 02-24-2008, 10:42 AM
homade's Avatar
homade homade is offline
homade has a very good reputation on FTE.homade has a very good reputation on FTE.homade has a very good reputation on FTE.
if it's the rubber mounts that are bad or your changing cab mounts as i did and need new rubber, i used the rubber rollers off a boat trailer, you can take a chop saw and cut the rubber to the lenght you need for each mount even if not the same, that way you can get the cab level by adding or subtracting thickness of rubber of mount, maybe i did't understand question, but a little trick i used when changing mounts.
Old 02-24-2008, 12:20 PM
Quote:
EDIT
I think that I jumped to the conclusion that the front steel cab corners were bad i. e. rusty. My mistake.
Old 02-24-2008, 08:34 PM
leonharu's Avatar
The sheet metal is good.I just want to replace the rubber pads in front and dog bone parts in rear.
F-4 cab mounts Marauder2004 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-25-2015 11:32 AM
Cab and core frame mounting pads honeyjbr 1967 - 1972 F-100 & Larger F-Series Trucks 4 02-16-2014 06:37 PM
53 F-100 upper cab mount cups jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 09-27-2013 01:49 PM
66 F100 Cab Mount ford66 1961 - 1966 F-100 & Larger F-Series Trucks 27 01-14-2010 11:11 PM
Cab Mounts Orange1975 1973 - 1979 F-100 & Larger F-Series Trucks 14 05-17-2007 11:43 PM
Tags
1948, 1952, 1960, 1966, 1972, cab, f100, ford, lift, missing, mount, mounts, pickup, rear, rubber, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
