Quote:
It could be. But make sure the engine is warmed up before pulling the codes. If it's below 50 degrees, it will spit out a code from the temp sensor.
Also make sure your throttle blade is clean, and is set correctly. If it's open too wide, or the idle air control motor is gummed up, it can stick and cause a high idle.
Thanks. Engine was warm (had just returned from a 15 mile trip and with a bad fan clutch, it gets really warm, will be working on that in a few days). Nothing seems out of the ordinary, it idled fine before the TPS went haywire. The EGR system appears to be totally shot as well, but I'm working on one problem at a time.
