Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
ATTN GURUS: WDS question/problem
Old 02-23-2008, 07:15 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I am trying to revive a WDS at my dealer and have run into a problem. I have reloaded the OS and WDS software and everything works great when the PTU is docked. As soon as I undock it, the PTU will restart by itself and run scandisk then when it almost gets to the select vehicle screen it will restart again. If I turn it on while undocked it will boot normally and then restart by itself right before the select vehicle screen. I have conditioned the battery and diagnostics says it is 100% charged and has no fault codes. I would really like to get this thing going so I can move it to my bay and not have to share an IDS with 8 other techs. I know it is obsolete but it connects faster than our IDS and the touch screen is a lot better than a laptop mouse pad.
Old 02-23-2008, 08:34 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Does this use a software key and is it up to date? Are you trying it with the vehicle connector attached?
Old 02-24-2008, 09:55 PM
70f100longbed
Ford discontinued the WDS in 2006 so I have the latest update up until then. I havent tried hooking it up to a vehicle but it shouldn't reboot by itself when undocking. I'm going to try the other WDS in the shop tomorrow and see if this one has a hardware problem. Thanks for the reply. BTW, have you ever used one?
Old 02-24-2008, 10:50 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Not that new of one. I used a Jaguar system (same basic machine) back in 2000 and it was very temperamental, would randomly reboot then an update made it do the same thing yours is doing.
Old 02-27-2008, 06:04 PM
blue beast's Avatar
blue beast
blue beast is offline
How is the board battery? That lithium is only good for about 7 years and needs to be
replaced if it has one.
Old 02-27-2008, 09:35 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
I vote for the battery too. Even thogh it says it's charged, it isn't.
Old 02-28-2008, 06:43 PM
70f100longbed
I think you guys are right. The other WDS in the shop works great so I think this one has a bad battery. Thanks for your replies.
Old 05-23-2011, 08:36 AM
mrwrench's Avatar
mrwrench
mrwrench is offline
where can I get parts for WDS ? or who fix them?
HarrysAuto
03-06-2017 11:10 AM
shuberhuber
2011 to 2019 Explorer
11-23-2016 11:35 AM
a3mariner
Escape & Escape Hybrid
04-05-2016 04:07 PM
CowboyUp1387
03-30-2012 12:30 AM
phw
1997-2006 Expedition & Navigator
06-13-2008 07:15 PM
Quick Reply: ATTN GURUS: WDS question/problem
