Can I change lower ball joint or must I swap control arm? - Ford Truck Enthusiasts Forums
Old 02-23-2008, 07:52 PM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
The Haynes manual says the ball joints on the lower control arms of the 95 and later Explorer are "not removeable or serviceable". The Haynes manual goes on to say "If the ball joint is damaged or worn, replace the control arm". Actually it says this about both the uppers and lowers, but I was able to change the upper control arms with new ball joints without too much trouble, but the lowers require a SPECIAL tool that holds the torsion bar while the lower control arm is removed. My local parts store has the ball joints in stock and say that they ARE replaceable. The aftermarket ones are held in place by a large snap ring. Can I put a jack under the lower control arm and remove the lower ball joints with the lower control arms still mounted to the vehicle? This would be a substantial savings. What tool would I use to remove the OEM ball joint? Is it riveted or bolted or pressed in place? I could remove bolts or drill out rivets. This is on a 2000 Explorer with 4.0L V6 pushrod w/auto trans and 2wrd.
Old 02-23-2008, 10:41 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Auto Zone will let you borrow a ball joint press to do the work. it looks like a big C-clamp with a tibe that fits over the ball on one end and a 1 inch jack screw on the other. you run it in with a ratchet or air gun and it pops the joint out. if you use a 5 poind hammer and beat it out, takes 10 x more time.
99 4WD Expedition, changing lower ball joints VTBoater Expedition & Navigator 7 12-14-2007 08:57 AM
2000 F150 lower ball joints kcbillo1 Brakes, Steering, Suspension, Tires, & Wheels 2 11-14-2006 09:48 PM
? on ball joint change oldstylefseries 1997 - 2003 F150 2 09-26-2006 10:38 AM
Ball joint troubles bassaway Ranger & B-Series 3 05-23-2005 12:00 PM
98 Ranger Ball Joints GreenBoonie Ranger & B-Series 11 04-15-2005 10:05 AM
Tags
2004, arm, arms, aviator, ball, change, control, explorer, f250, ford, joint, joints, lower, replace, swap, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
