HELP! ive got wierd noises
I have an 03 f-350 6.0 powerstroke. whenever i stop, i get a consistant vibration. i do not think that it is my abs. sometimes it will continue to vibrate while the truck is completely stopped and the speed and volume of the sound does not change. it is a constant noise when the brakes are applied. it does it worse with weight on the front end of the truck. i plow in the winter so its very noticable right now. any thoughts on that sound will help.
Also, i get a second noise when i turn or go over bumps. its typically a single pop.
all noises are coming from the front end. any help would be appreciated.
I've got an 03 F250 with 61K on it...I just bought new front rotors because my fronts are warped. My fronts vibrate when I brake...worse when I'm going downhill, and really bad when I've got weight in the truck...sounds like your plow issue.
It doesn't make sense that the vibration continues after you've stopped. That would indicate something is loose and it continues to viberate after you stop.
The single pop going over a bump could be several issues. How many miles on yours? How long has it been doing this?
Joe
Joe
Originally Posted by kevinwebster1
ball joints were replaced a little over a month ago, i had thought the same thing and tires plus had told me that there was play in them so i had them go ahead and replace them.
this may be a dumb question but i honestly dont know hardly anything about ford super dutys (mainly cuz i dont usually have problems with the truck, so i dont ever tear into it!!!) anyway, is there anything like a chevy has cv joints with u-joints. to where when i would turn a u joint or something would be poppin??? just a thought, i may be way off.
Yes, you have 4X4 then you have u-joints at the ends of the front axles... something worth looking into. Mine has all new ball joints and still "pops" as well when going over bumps and turning at times... I suspect it has to do with the bushings on the sway bar or on the leaf springs... I'll check it out after things warm up and the snow melt dries up!
