Need Blend Door Procedure-98 F-150 5.4
Old 02-23-2008, 10:47 AM
hoganlo's Avatar
hoganlo
hoganlo is offline
Does anyone know where I can find the blend door procedure for a 1998 F-150 5.4? I seem to have the issue where it blows cold, temp control **** has no effect but if I hid a road bump hard enough I luck out and start getting heat.
I just don't know the proper process to get to and remove and exactly what I'm looking for. Any help would be appreciated!!
This site has saved me a ton!!!
Steve
Old 02-23-2008, 05:00 PM
hoganlo's Avatar
hoganlo
hoganlo is offline
Update on Blend Door
Okay...after reading other posts I've taken off the plastic over the tranny hump and pulled out the plastic that directs the air flow. I have removed the little white box...not sure what this is actually called (actuator/blend door motor?). Anyway, I turn the temp **** and the shaft turns just fine on that motor...the white shaft fits into a black hole/tube and I can actually turn the tube, but the temperature does not change.
What next? I assume that there is a door that rotates when the shaft and tube turn, but I don't see it or how I get to it at all.
Old 02-27-2008, 04:38 PM
sheetsd66's Avatar
sheetsd66
sheetsd66 is offline
I did a google search for 1999 F150 blend door and started clicking on links. I can't remember the exact site, but I found a forum similar to this one with excellent pictures. I just replaced mine about a month ago, give yourself plenty of time. Its an all day job. You may want to double check the operation of the door itself; you said that when you turn the tube the temperature doesn't change... it should. Make sure you turn it all the way through its range of travel. You should feel at least a slight temperature change thru the vents.
Old 06-19-2008, 07:12 PM
yekratsb's Avatar
yekratsb
yekratsb is offline
2nd Gear
How in the world did you get the plastic out that directs the air flow? I'm trying to pull out the actuator without removing the black ducts below it but I can't seem to push it down far enough to pull the white shaft out. Does the shaft disengage from the actuator?
Old 06-21-2008, 09:35 AM
hoganlo's Avatar
hoganlo
hoganlo is offline
I used an angled screwdriver. I have the lower section taken out and still have not completed the job! Been driving around half torn apart for over a month!! When I accelerate, the door flops over to heat so I turn the air off...I've gotta get this thing foxed, but haven't had any time.
Old 06-21-2008, 04:03 PM
sheetsd66's Avatar
sheetsd66
You gotta pull the dash to get at the blend door. You can get the replacement door from NAPA ($12) or the dealership ($40).
Blend door replacement with pictures - F150online Forums
Old 06-22-2008, 06:40 PM
hoganlo's Avatar
hoganlo
hoganlo is offline
Thanks sheets! Hopefully I can tear into this soon!!
Brian Frank
05-24-2016 06:41 PM
Steve0623
1997-2006 Expedition & Navigator
02-23-2015 06:09 AM
TheProfessorofTOOL
1997 - 2003 F150
12-19-2013 09:15 PM
nbafreak2007
1997 - 2003 F150
12-20-2008 01:31 PM
Steve Ga
01-15-2008 06:13 PM
Quick Reply: Need Blend Door Procedure-98 F-150 5.4
