Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-23-2008, 11:47 AM
hoganlo is starting off with a positive reputation.
Need Blend Door Procedure-98 F-150 5.4
Does anyone know where I can find the blend door procedure for a 1998 F-150 5.4? I seem to have the issue where it blows cold, temp control knob has no effect but if I hid a road bump hard enough I luck out and start getting heat.
I just don't know the proper process to get to and remove and exactly what I'm looking for. Any help would be appreciated!!
This site has saved me a ton!!!
Steve
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2008, 06:00 PM
Update on Blend Door
Okay...after reading other posts I've taken off the plastic over the tranny hump and pulled out the plastic that directs the air flow. I have removed the little white box...not sure what this is actually called (actuator/blend door motor?). Anyway, I turn the temp knob and the shaft turns just fine on that motor...the white shaft fits into a black hole/tube and I can actually turn the tube, but the temperature does not change.
What next? I assume that there is a door that rotates when the shaft and tube turn, but I don't see it or how I get to it at all.
  #3 (permalink)
Old 02-27-2008, 05:38 PM
sheetsd66 is starting off with a positive reputation.
I did a google search for 1999 F150 blend door and started clicking on links. I can't remember the exact site, but I found a forum similar to this one with excellent pictures. I just replaced mine about a month ago, give yourself plenty of time. Its an all day job. You may want to double check the operation of the door itself; you said that when you turn the tube the temperature doesn't change... it should. Make sure you turn it all the way through its range of travel. You should feel at least a slight temperature change thru the vents.
  #4 (permalink)
Old 06-19-2008, 08:12 PM
yekratsb is starting off with a positive reputation.
How in the world did you get the plastic out that directs the air flow? I'm trying to pull out the actuator without removing the black ducts below it but I can't seem to push it down far enough to pull the white shaft out. Does the shaft disengage from the actuator?
  #5 (permalink)
Old 06-21-2008, 10:35 AM
I used an angled screwdriver. I have the lower section taken out and still have not completed the job! Been driving around half torn apart for over a month!! When I accelerate, the door flops over to heat so I turn the air off...I've gotta get this thing foxed, but haven't had any time.
  #6 (permalink)
Old 06-21-2008, 05:03 PM
You gotta pull the dash to get at the blend door. You can get the replacement door from NAPA ($12) or the dealership ($40).
Blend door replacement with pictures - F150online Forums
  #7 (permalink)
Old 06-22-2008, 07:40 PM
Thanks sheets! Hopefully I can tear into this soon!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
