Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-23-2008, 11:25 AM
mh34444's Avatar
mh34444 mh34444 is offline
mh34444 is starting off with a positive reputation.
Another DPFE --- 0401 Code --- What haven't I troubleshot yet?
I know this is a truck board, but I can't find a reliable board for a question about my Escort. DPFE problems seem to be problems across all the vehicle platforms, so here it goes.
I've gone thru 4 DPFE sensors in the past 2 years, it would be more but I just let the engine light stay on until I notice a change in fuel mileage. After a new DPFE sensor is put on I get around 3000 miles before it goes belly up again. It always gives me the 0401 code (insufficient flow detected) and always shows stuck at high voltage when it goes bad. I've tried 3 different manufactures (motorcraft twice) and the result is always the same. I have cleaned the exhaust tube, the egr ports and replaced the EGR valve even though it tested fine. There were no carbon deposits in any of them. I've replaced both rubber inlet and outlet hoses on the sensor, neither of which had any cracking on them. I took it to a shop once, only to get told what I already knew, "the DPFE is bad."
What am I missing? I've resorted to making the swap part of my oil change routine. Spending the $60 on a new sensor every time has so far been cheaper than bringing it to a shop again.
__________________
05' Ford F350 XLT PSD
73' Ford F100 Ranger
Tags
0401 , dpfe , f250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
