Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-23-2008, 07:50 AM
polarisman729's Avatar
polarisman729 is starting off with a positive reputation.
no start issue
Hey guys,
I'm about ready to crush this truck if I can't figure this out. I've got an 86 f-150 with the 302 EFI. I was having some problems with the ignition and fuel pumps and I thought I got them squared away. Well I guess not. THe other day I was driving home and the truck died. I checked to see if the fuel pumps were running and they weren't. I was going to change the frame rail pump but I pulled it and tested it and it was fine. So i figured it was something electrical. I checked the ground to the batt and it was bad so i fixed that. Pumps working again. BUT.....BUT now it won't start. I sprayed some ether to see if it would fire and nothing......I had ignition problems before and I replaced the coil, cap and rotor, plugs, wires, and the control module. I also fixed some shabby wiring. After all of that she ran fine.....until the other day. Well, I checked to see if it was getting spark and it is at the coil and at the plugs. It just won't fire. I have no ides where to go from here. Is there some dummy switch i'm missing? Can anyone help me?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2008, 08:14 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Run a test and see if you have any codes. Here's a website that tells you how to do it with a testlight. www.fordfuelinjection.com
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 02-23-2008, 05:10 PM
I tried running any codes but i couldn't get it to work for me......another culpret of bad wiring.....
  #4 (permalink)
Old 02-23-2008, 05:42 PM
Franklin2's Avatar
Check for grounds from the computer harness to the battery negative. You are probably correct, bad wiring is going to really hurt your chances of fixing it. You may need to get a schematic and just go over the whole thing.
__________________
Dave F
  #5 (permalink)
Old 02-23-2008, 11:14 PM
i figured it out......i had the wires going to the fuel pump backwards.....i'm an idiot. It only took me two days to figure that out.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
