Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 02-22-2008, 08:26 PM
bucketobolts bucketobolts is offline
Garage is empty, add now
bucketobolts is starting off with a positive reputation.
DRW Axle?
I'm wanting to swap my '78 250 to a dually 350. Anyone have or know of a dual rear wheel axle for sale in or near NC?
  #2 (permalink)
Old 02-22-2008, 08:29 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
I don't have a clue, but hey welcome to the NC chapter.
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #3 (permalink)
Old 02-25-2008, 10:37 AM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
i use to have a set. but you need to make sure the axle you find is not off a cab and chasis truck if it is it wont fit. the frames are a different.
__________________
73 ford ranchero gt (rebuild stage)
Will the last american > PLEASE grab the Flag
  #4 (permalink)
Old 02-25-2008, 03:32 PM
Thanks for the info. I'm guessing the frame is narrower on a cab/chassis? My frame measures about 35" across the front rails and 37.5" across the rear.
  #5 (permalink)
Old 04-07-2008, 10:36 PM
yes cab and chassis is narrower.
__________________
  #6 (permalink)
Old 04-07-2008, 11:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Cab and chassis rear frame is 34"
Complete truck rear frame is 37.5"
Cab and chassis rear axle is identical to a SRW axle when measured back plate to back plate, just the spring perches are closer together on the cab and chassis axle.
A true dually axle is 4" wider than a SRW axle when measuring back plate to back plate.
Returning you to your regularly scheduled forum now.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Tags
axle, drw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
