tow/haul light flashing - Ford Truck Enthusiasts Forums
Old 02-22-2008, 05:55 PM
balljoint balljoint is offline
balljoint is starting off with a positive reputation.
I have a f-250 diesel 4x4 auto. trans. My check engine light came on, and then my tow/haul light started flashing. Idrove straight to my local ford dealer to get it checked out. they replaced the ICP sensor and hardware. theysaid that was the problem with the engine light, but I needed to replace the transmission. They gave me a quote of $3,700. I have never had any problems with the tranny, Itow a 38 ft. 5th wheel, and it preforms fine every time. And when I left the dealership the light was not flashing. Has anybody had a problem with the tow/haul light flashing?
Old 02-22-2008, 07:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The tow/haul light flashes when the is a problem with the transmission. Without knowing what code was set it's impossible to know what's wrong. It could mean a new trans, but more likely it's something minor. Try somewhere that's better at diagnostics to get the trans code read. Many independant shops can't read Ford trans codes.
Old 02-22-2008, 08:45 PM
Thanks for the input Mark, I will get it testd again, but do you think it will hurt to drive it for a while? I dont have that kind of money right now
Old 02-22-2008, 09:55 PM
liv liv is offline
liv is gaining momentum as a positive member of FTE.
Quote:
He said he took it to a Ford dealership.
I doubt you have a problem with the transmission if you said its running great. You'll know when you blow a tranny.
I would take it to a different dealership though and see if its throwing any codes just to be safe.
Old 02-23-2008, 12:51 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
My tow-haul light came on while towing today. After a quick check, I found that it was simply that I did not have the plug in tightly. A bad connection will cause the light to flash.
Old 02-23-2008, 04:35 AM
buba 11 buba 11 is offline
buba 11 is starting off with a positive reputation.
My tow-haul light started flashing one day also,
Checked for trouble codes and found code for a bad transmission temperature sensor.
$65.00 at my local Ford dealer and a pain in the $%$ to change because you need to drop the transmission pan to install it. Used this opportunity to change the internal screen and fluid and recycle some of that old moldy money which had been collecting in my wallet.
Funny thing, the transmission was mis-shifting badly with the old sensor but the new one corrected the problem.
Every day with the 6.0 is a new learning experience!
Old 02-23-2008, 07:42 AM
Quote:
I saw that. Unfortunately that doesn't mean they know what they are doing.
He has a problem with the trans. The light is flashing which means there is a problem with the trans. It's probably minor because he doesn't notice a problem. If he keeps driving it he will know when he blows the trans. If you keep driving a trans with a small problem it usually turns into a destroyed trans.
That's what I meant.
Old 02-23-2008, 08:40 AM
paddler65 paddler65 is offline
paddler65 is starting off with a positive reputation.
balljoint
sorry about tranny.
if you are towing a 38'5ver with 3 or 4 slides you may be towing more than that tranny was builted for. have the truck and camper weighted.
Old 02-23-2008, 08:54 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE.HeavyAssault is gaining momentum as a positive member of FTE.
There have been posts of the VSS on the rear diff going bad causing the TOW/HAUL light to blink. It's a DIY repair if you get the new sensor.
Old 02-23-2008, 10:00 AM
MOB.Diesel-350 MOB.Diesel-350 is offline
MOB.Diesel-350 is starting off with a positive reputation.
mine flashed a while back when towing up in the mountains. pulled two codes, forgot what they were but both related to the clutches. dropped the pan for inspection and a whole lot of shavings in the pan. and it too felt fine, for the most part. i could feel it slip between 1 & 2. $3700 for a stock trany, yikes. i decided to spend $4900 and have it beefed up. shifts like a monster now.
TOW/HAUL PROBLEM 9218xz 1999 to 2016 Super Duty 4 01-28-2016 07:52 AM
Trans Problems- Codes n flashing lights Dominating 6.0L Power Stroke Diesel 15 06-16-2012 05:21 PM
Tow/Haul switch started blinking? TruckoffFord 6.0L Power Stroke Diesel 6 04-19-2012 06:05 PM
Tow/Haul icon flashing Nathan 1999 to 2016 Super Duty 2 12-02-2010 04:53 PM
03 f250 6.0 with torqueshift problems timsfordtruck 1999 to 2016 Super Duty 1 07-21-2009 03:43 AM
Tags
2004, 2005, blinking, blinks, f150, f250, f350, flashes, flashing, ford, haul, light, tow, towhaul, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
