Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-22-2008, 05:14 PM
peckhamjusten is starting off with a positive reputation.
shortage help....
i have an 89 buick lesabre n the other day i had summin hooked into the cigerette lighter and 2 wires on the device crossed shortin out the the cigerette lighter so it no longer works and there is nothin on the radio, all i get is interference n no display shows up nor kan i change the channels or nothin. im a lil confused as to if this would b a fuse problem or not. the only 2 things affected by this that im aware of are the 1) cigerette lighter not havein any power and 2) no radio frequencies. thank you for ur help cus i have no idea wat this could b cus ive never heard of this happenin before.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2008, 09:52 AM
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Check your fuses. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #3 (permalink)
Old 02-23-2008, 10:13 AM
johnny567's Avatar
johnny567 is starting off with a positive reputation.
check you fuses as jimdandy said, most radios have 2 hot wires, 1 switched lead & 1 constant hot. one of them is probably on the same circuit as the lighter.
__________________
2004 f-250, 6.0, crew cab, shortbed 4x4.pull-rite 5th wheel hitch,air lift air bags,autometer gauges,code remote start & alarm,pioneer stereo,alpine amp, jl audio 10` sub, magnaflow muffler & my cat ran away.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
