carburetor jets - Ford Truck Enthusiasts Forums
carburetor jets
Old 08-29-2002, 06:23 PM
horsepower horsepower is offline
horsepower is starting off with a positive reputation.
carburetor jets
what size carburetor jets for a 1978 Ford Bronco with 400M and motorcraft carburetor?
Old 08-29-2002, 08:29 PM
garypettengill's Avatar
garypettengill garypettengill is offline
garypettengill is gaining momentum as a positive member of FTE.
carburetor jets
I'm in Ohio and I run 57's in mine.
Old 08-29-2002, 09:51 PM
fordmanSLO fordmanSLO is offline
fordmanSLO is starting off with a positive reputation.
carburetor jets
With all the smog stuff, and at about 100-200 ft elevation, in CA, I run 60's, and passed smog just fine.
Old 08-30-2002, 11:20 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
carburetor jets
Bad Carburetor? fixorrepairdaily100 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-08-2013 07:08 PM
Carburetor Question SGT DuckButter Large Truck 5 08-09-2012 12:54 PM
General Carburetor Jet Question Rick_Fury 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-14-2011 08:52 PM
Proper way to drain carburetor float bowls? RabidJade General Automotive Discussion 1 12-14-2010 07:15 AM
2150 carburetor main jet size Skyman Fuel Injection, Carburetion & Fuel System 2 10-05-2004 09:44 AM
Tags
200, 400, 400m, bronco, carb, carburators, carburetor, carburetors, f2j047, ford, jet, jets, main, parts, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
