Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-22-2008, 02:55 PM
jonkuehn49 is starting off with a positive reputation.
96 B4000 Frontend Driveline Grinding Noise
I have a frontend driveline grinding noise that ONLY occurs when the hubs are engaged and while coasting. Doesn't matter if the transfer case is set to 2wd or 4wd. The noise goes away when giving it some gas... even the slightest amount. Sounds like it is coming directly under the engine, not off to the side. My initial thought was the u-joint... it had rusted up once before. I'm driving a 96 B4000 with manual hubs (thanks to everybody that recommends them). Any thoughts?
- Jon
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-22-2008, 03:02 PM
Pablo-UA is starting off with a positive reputation.
I suggest CVs... May be boot is bad, water washed greeze out and CVs are worn inside. Many year ago I had FWD car. Bad boot was a usual problem causing exessive CVs wear..
  #3 (permalink)
Old 02-22-2008, 10:30 PM
pintopower8 is starting off with a positive reputation.
may also be bad bearings
__________________
2 year Associates Degree in Automotive Technology Chrysler Dealership experience
Present diesel technician
Specialty- Driveability complaints caused by fuel, and ignition failures, Electronics, general automotive theory, scan tool and Lab scope diagnosis, electrical circuitry.
  #4 (permalink)
Old 02-23-2008, 08:11 AM
It's only happening when the hubs are engaged. Would bad CV joints and/or bearings be effected by hub engagement?
  #5 (permalink)
Old 02-23-2008, 10:15 AM
aquanaut20's Avatar
aquanaut20 is starting off with a positive reputation.
Quote:
When the hubs are disengaged the drive line is not moving, hubs engaged driveline is active all the way to the T/C.
  #6 (permalink)
Old 02-25-2008, 08:44 AM
Thanks for the suggestions. This gives me a good start on what to look for. Hopefully it's obvious (ripped boot).
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
