WAFTE Archived Buy/Sell/Trade ADs
#408
1997 460/7.5 MAF setup complete with ECU, full engine bay harness, intake piping, throttle body, air box, MAF, fuse panel $1,500 obo LOWERED
67-72 F-series "Contractor Special" behind the seat box $200 obo LOWERED
Last edited by oddfordjunkie; 09-17-2014 at 08:35 PM. Reason: Item sold X2, added pictures, lowered prices
#410
my other pump is an engine oil pump from a ford 300-6, bolted to a board and driven by a drill. some fuel leaks out of it, so thats a downside, but very fast priming and strong output. simply have to tap pipe threads into the ports and add hose barbs or whatever you like.
sean, its been awhile! maybe since i'm down here in renton i'll try to make it to one of the monthly meets one of these days
#411
i have a couple pumps that i use for diesel and alternative fuels. i don't intend to sell one right now, but thought i'd pass on the ideas. one is a power steering pump from an 80s toyota pickup, pulled from the junkyard. its bracket is bolted to a board, and an electric motor next to it, with a simple v-belt between them. its a little slow to self-prime if the suction line is long, but performs quite well for transferring and filtering. the pump comes with a 5/8" suction hose, ready to replace with a section of garden hose or whatever you like.
Would be good to say hi.
I like the idea of the power steering pump. How well does is
do for pressure? I have 25 Gallons of diesel I need to filter well.
Got a little gunk in it but other wise good.
Hope you can make this month at Jimmy Macs. Yummy!
Sean
#415
I am not sure I just know that they need to be HID bi-xeon.
I think the lamp style would be the D2S and will have the
shutter for low beam.
Sean
Sean
#417
How about a Ready Lift 5" rear block kit.
Kit was installed and removed. Wrong kit for truck.
Stupid people at the shop said it was the right one
and by the time I got back to them 2 weeks later they
were belly up. Kent 4Wheel Drive Silly noggins.
Long Bed Crew Cab does not use the tapered blocks.
Asking $140.00 and it's all there and clean.
Sean
Sean
#419
Already have F350 blocks.
When I was on the phone with them.
They did say that they do have square ones
for people with my application.
Sean
Sean
