Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-22-2008, 11:00 AM
old uhaul is starting off with a positive reputation.
5.4 swap into a 77 F-350
I have a 77 F350 2wd dual wheel truck with a 330 FE.I just got in a 2004 econoline van with a 5.4/auto.
Has anyone swapped a mod motor into a 73-79 2wd,mainly worried about the oilpan fit with the twin ibeam crossmember.Also is there an aftermarket wiring harness available for a 5.4?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-22-2008, 06:57 PM
92f150I6's Avatar
92f150I6 is starting off with a positive reputation.
I did see an article on here where a person swapped a 5.4 into a 78-79 Bronco, and it fit with some frame clearance cutting. As for wiring, he used the donor vehicles wiring and computer which may be your best bet since you have a donor vehicle.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
  #3 (permalink)
Old 02-22-2008, 07:34 PM
andym's Avatar
andym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud of
This is popular one lately.
http://home.comcast.net/~qcrispin/bronco/
__________________
Andy
1989 F-150 XLT Lariat Shortbed 4x4 300/T-18/3.55
1990 Bronco Eddie Bauer 4x4 351/E4OD/3.55
Quote:
It often takes more courage to change your opinion than to stick to it.
Election 2008 results: World's worst job given to a black man.
  #4 (permalink)
Old 02-23-2008, 06:55 AM
That is a great job on the bronco.I was hoping to find someone who had done a swap into a 2wd truck.
  #5 (permalink)
Old 02-23-2008, 02:07 PM
1967 Turbo 6.9 is starting off with a positive reputation.
You wont have the room that a 4X4 can offer but clearance of the engine oil pan isn't the tight spot. I found the transmission clearance a big problem. Fuel tank & floor brace. I had to put My 6.9 at just the right height to miss the steering box to. Not a big step for any builder.
__________________
2000 F250 7.3 CrewCab, 1986 F250 6.9 SuperCab
1967 F350 6.9 Banks Turbo GV overdrive
57 County Sedan, Me and Fairlane's, 57 Fairlane Blown 460
Son's 1974 F100 428CJ soon to get a 6.9 Diesel
2000GT ,1990 LX 514ci
  #6 (permalink)
Old 02-28-2008, 09:24 PM
427SOHC's Avatar
427SOHC is starting off with a positive reputation.
I have installed a mod motor in my 79 F100, I have a 4.6 liter 32v DOHC Lincoln engine.
I am reusing the entire wiring harness with computer. I have some pictures in my gallery, it is SLOWly coming together. My motor mount brackets are tubular steel with gussets welded in for additional strength and the factory 79 F100 tranny mount was reused with a redrilled tranny crossmember.
Headers are street rod style from Sanderson. I am doing the math to install the IRS from the Mark 8 as well.
  #7 (permalink)
Old 02-29-2008, 07:24 AM
Looks like it comming along nicely!I will be using the factory wiring harness and computer.I see you changed the front suspension,did you have problems fitting the engine with the original crossmember and steering box?
___________________________
1977 F350 box truck
1956 F100 panel
1956 F100 pickup
  #8 (permalink)
Old 02-29-2008, 10:33 PM
427SOHC's Avatar
I purchased a complete hub to hub IFS kit from Fatmans Fabrication, the original crossmember was replaced with the one from the kit and the steering is rack and pinion from a mustang II which also came with the kit.
The new crossmember sets approx 3-4" off the ground with the air out of the bags.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
