If you find a port for the oil, I'd like to know too. I haven't found a spare one yet and I don't think Teeing the stock oil pressure switch will fit very well.
For the trans temp you have two options, From factorytech's web page
Quote:
Where can I install my fluid temperature gauge?
On the passenger side of the transmission, there is a test pressure port with a pipe plug in it, you can remove this pipe plug and install your temperature or pressure sending unit here. Most gauges are already the correct size or come with adapters to fit it.
or autometer has a temperature manifold that you cut the cooler line and clamp it inline.
I think there are two ports in the intake manifold water cross over that you can tap for the water temperature.
