Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-22-2008, 06:40 AM
Stretchstick is starting off with a positive reputation.
351W erratic idle and loping
I have a '73 Bronco that I just swapped in a 351W. I bored it .30 with flat top pistons, P&P the heads with full roller rockers, balanced and blueprinted and an RV cam. I also installed the Edelbrock Pro-Flo MPI Fuel injection system that included an MSD distributor. Also in there is the MSD 6 off road box and Blaster 2 coil.
7At idle, the engine will run smooth for about 5-7 seconds, then drop about 500 rpm, then run up about 250 rpm above idle, then repeat. When it is cold, it will stall when the rpm drops until it warms up.
I was pointing fingers at the Edelbrock system, but my neighbor has done about the same exact things to his 351W, except he did a stock Ford fuel injection and he is having the same issues.
Any advice is greatly appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-22-2008, 10:50 AM
Mike G is starting off with a positive reputation.
First off, let me say welcome aboard!
Secondly, considering what you have sitting on top of that motor, I would call the Edelbrock guys. Seems to me there is a computer/ecm issue in there where it is reading your flow data.
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
