1978 Dana 60 value and rarity?
#33
Dana 60
They 78-79 Dana 60 high pinion brings about $1000 on ebay in used condtion, they fit right into the older "Highboy" F-250's the spring pads are the same width, shock mounts and steering are bolt-in's also. Not sure if driveshaft has to be cut, mine was already in my 76 when I got it. I got a extra 4.10 D-60 hp with calipers if anyone is looking.
#38
axles
Thats what i ended up doing. i posted a wanted item on craiglist and been searching ebay. I recently bought a 1978 ford bronco and just love it to death. the money im getting back from my taxes is going to help fund my project but anyway i have 460 bored 30 over with cj heads im putting in it and i was going to put a D60 high pinion front axle with a GM 14 bolt 4.56 gears in the rear then realized i didnt want any gm parts on it so i changed my mind to a Ford D70 rear axle. I have never really done anything with axles before just messed around fixn motors so i was/am unsure about how hard this will be will any D60 front axle fit on my bronco or do i need a ford 77.5 to 79 F350 axle? and same with the ford D70 rear axle?
Thanks
Thanks
#39
#41
A D70 in the rear is fairly straight forward, all you need are the ubolts and plates from the truck the axle came from, bolt it all up. The front is another can of worms. Either you have to make that 60 fit your factory radius arms, or add leaf springs to the front end. Either way I suggest you search the offroad forums, also full size bronco(one word) dot com is a great resource for what you want to know as well.
#42
shehan
Ford Truck Parts for Sale
01-12-2017 02:38 PM
shehan
01-12-2017 10:08 AM
twofifty
08-06-2016 10:49 AM
BlueOvalBud
08-15-2010 09:56 PM
