What kind of engine are you worknig with? I assume a flathead, since you're talking about RedsHeaders?
If so, you have to be careful on the flatties, or you can have the valves smack into the higher compression (smaller chambered) heads without some prep work on them.
But yes, in general raising compression ratio and adding a freer flowing exhaust is good for more power and a more efficient engine
