distributor frozen in block
1978 F-150 400M, C-6, dead stock and no more that a starter, radiator, choke pull off and that type work before now. 89,000 miles.
My 1978 truck shop manual says my '78 400M distributor will pull out if I remove the hold down bolt and tab, and the distributor will lift up out of the engine block. I took off the bolt and hold down tab, but can't budge the distributor.
The distributor housing won't turn in the hole either.
I now have everything torn down in the motor, but I can't extract the cam with the distributor gear still in mesh with the cam gear. I can rotate the shaft and shift the cam forward and back 1/2", so the gear is not bound.
To try to free the distributor from the block I have tried liquid wrench soaking from both sides, tapping the underside of the distributor with wood and metal punches, heating the block with a propane torch and repeating all the above, tapping the side of the distributor to attempt to turn it and trying to wedge under the lip of the distributor with a wood chisel.
Anybody have any ideas??
I finally got it out. I moved it a little with an oil pump strap wrench, tapped on the side lug again with a hammer - in both directions and began to see a little shifting. OK, I broke off the sides of the distributor casting on both sides of the wire cut out, but I can glue them back on with JB Weld. But it moved.
I then turned it upside down again and was able to drive it out with a 7/16 solid aluminum rod I had. Did dent up the bottom of the casting lip, but it shifted the distributor 1/2" up and then I could work it out. When I put this back together, I am going to coat it with grease so the water inlet doesn't seap and drip right down to puddle around the distributor. I'll also get a bunch of the copper stuff for it. After I hone out the corrosion, I may need a sleeve to make it stay in the block. Did I tell you I love to work on my truck?
HarryPutnam
05-21-2011 07:26 PM
therealulysses
13
01-10-2011 11:59 AM
unixadm
13
10-26-2007 12:53 PM
lmadore
10-25-2005 07:53 AM
AmeriKen
10-09-2005 12:24 AM
