camper shell heater mod - Ford Truck Enthusiasts Forums
Old 02-21-2008, 06:45 PM
1983 3004x4's Avatar
1983 3004x4 1983 3004x4 is offline
1983 3004x4 is starting off with a positive reputation.
My idea is to tee off the block and run the hoses down the passenger side under the cab to quick disconects in the bed. I'm going to bulid a box for the fan and heater core with a handle to remove when i need or want bed space. any ideas or suggestions are welcome and thank you all for your help.
Old 02-21-2008, 07:48 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
Sounds like it would work. I would insulate the lines from the outside the best that I could though, maybe run them inside of another larger rubber line. Take some pics if you do it.
Old 02-21-2008, 11:05 PM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
If I am understanding this correctly, you would have to have your engine running to get heat in the camper/canopy. Wouldn't a small "indoor safe" propane heater work for you? Something like a Mr Buddy heater?
Old 02-22-2008, 12:53 AM
Quote:
No. I plan on insulating the bed and shell to hold the heat longer and putting a 12 volt pump in to circulate antifreez.
Old 02-22-2008, 01:14 AM
chrono4's Avatar
With it like that, you would still only get a pretty limited amount of heat from the motor after its off.
Old 02-22-2008, 09:38 AM
blue beast's Avatar
blue beast blue beast is offline
blue beast has a good reputation on FTE.blue beast has a good reputation on FTE.
I would use a set of valves so I could control where my coolant is flowing in case I
just wanted cab heat or just bed heat, either manual or vac controlled valves. A old
street bike radiator or even an a heater plenum out of a small car and leave it together
with the fan and everything enclosed in a plastic plenum(match the sqft heated space)
A remote starter would be a good thing to have and tie it in to a thermostat so when
hit a certain temp it would start up and reheat the system. A small auxillary electric
water pump on a 555 timer circuit to circulate the water every 5 minutes for say 2 min
to get some of the heated and trapped water out of the block and into the bed.
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/egnsea...+115&x=22&y=13
I would put an extra battery in case the water pump sucked down the juice(5amps)
sitting there for a long time, At least a voltmeter in the bed so you know the level.
Old 02-22-2008, 04:40 PM
is there a remote starter an 83 F-150 with a 4spd trans?
Old 02-22-2008, 04:52 PM
chrono4's Avatar
More than likely not, but it's nothing you couldnt set up. Using a relays or some and/or gates to trigger power to the solenoid for a preset time or using a tach signal to shut off solenoid power. Have it give the ignition power for a preset time to warm it back up, then kill the ignition power. You would just have to make sure that it's always in neutral and the e brake is set.
Old 03-02-2008, 03:03 PM
flathead95hp's Avatar
flathead95hp flathead95hp is offline
flathead95hp is gaining momentum as a positive member of FTE.flathead95hp is gaining momentum as a positive member of FTE.
Quote:
It does work, when Dad bought the one I have in 77, he put a heater in the back of the truck for us kids, He took the system out of a firetruck and boy did it work well, He built custom cabinets to keep stuff in and even had it carpeted so we would have some insulation against the cold bed floor.
heating Kenneth J Kirkland 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-23-2016 03:47 PM
Defroster plenum SeaCarr 1957 - 1960 F100 & Larger F-Series Trucks 6 04-18-2016 11:28 PM
Need seal for heater core. 4x4 Bart 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-07-2014 01:39 PM
Heater for F 100 Max E 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 09-05-2008 12:55 AM
How long is to long to leave block heater plugged in, Brian02350 1999 - 2003 7.3L Power Stroke Diesel 8 12-07-2002 05:25 AM
Tags
camper, cheap, elkhart, f150, f250, ford, heat, heater, insulate, insulated, insulating, mod, modification, shell, shells, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
